8N throttle spring connection???
Jerrycpp(WA)
PostPosted: Fri Aug 10, 2007 8:02 pm    Post subject: 8N throttle spring connection??? Reply to specific post Reply with quote
Well, it's been 2 years since I tore my side mount 8N apart, and now I can't remember which way that little triangular piece of metal goes on. It's the one that mounts on the bell housing and the throttle spring hooks onto it. Does the little spring hole go up or down? It is bent like down, but that makes the spring awfully tight. Any help would be most appreciated.
Flyer
PostPosted: Fri Aug 10, 2007 8:46 pm    Post subject: Re: 8N throttle spring connection??? Reply to specific post Reply with quote
Jerry, I believe the hole points down. I checked a few tractor pictures before I bolted mine in place. HTH Flyer
8N'r--WI
PostPosted: Sat Aug 11, 2007 4:32 am    Post subject: Re: 8N throttle spring connection???PICTURE Reply to specific post Reply with quote
Jerry---I hope this helps.---Tim
Jerrycpp(WA)
PostPosted: Sat Aug 11, 2007 7:46 am    Post subject: THANK YOU Reply to specific post Reply with quote
Thank you - that's exactly what I needed. And thanks to Flyer too. This forum has bailed me out more times than I can count!
