New head casket, now she's not turning over.
Farmer Frank
PostPosted: Wed Aug 08, 2007 6:10 pm    Post subject: New head casket, now she's not turning over. Reply to specific post Reply with quote
Hey all, just finished putting on a new head gasket and got her put back together, now she won't turn over. I checked all of the connections including battery cables. I'll put the charger on her in the morning, but just wondering if there is something magical I need to do to get her to turn over? I just had someone replace the wiring harness and he put on a new switch. It was running before I worked on it. If the switch was left on, would that drain the battery? I'm thinking not, but not sure what else it could be. Any other suggestions?
Farmer Frank
PostPosted: Wed Aug 08, 2007 6:11 pm    Post subject: Re: New head casket, now she's not turning over. Reply to specific post Reply with quote
Forgot to add that she's a 6 volt.
Farmer Frank
PostPosted: Wed Aug 08, 2007 6:12 pm    Post subject: Re: New head gasket, now she's not turning over. Reply to specific post Reply with quote
It's late again... gasket, not casket.
OKDAD
PostPosted: Wed Aug 08, 2007 6:21 pm    Post subject: Re: New head casket, now she's not turning over. Reply to specific post Reply with quote
Hi FF,
A little more info would be helpful.
1. Does the relay click? If so does the starter try to turn her over?
2. Do you have a voltmeter? Is there any voltage at the battery terminals and relay terminal?
Rgds,
Ike
old
PostPosted: Wed Aug 08, 2007 6:27 pm    Post subject: Re: New head casket, now she's not turning over. Reply to specific post Reply with quote
If you left the switch on yep DEAD battery plus bad points and if a front mount coil its probably fried also.
Hobby farm
souNdguy
PostPosted: Thu Aug 09, 2007 4:32 am    Post subject: Re: New head casket, now she's not turning over. Reply to specific post Reply with quote
I agree with old.. if the switch was on..and the poitns were closed.. I'd look at replacing points, and if a front mount coil. that too.. plus the battery will be flat..
Pull the spark plugs and let them dangle on their wires while you are charging the battery.. block clutch down.. now try to bar the engine over and make sure nothing is stuck accidentally from the head gasket change..
If it spins ok.. reinstall the plugs and roll her over with the starter and see if you can get spark..
Soundguy
Rick(IA)
Guest
PostPosted: Thu Aug 09, 2007 10:40 am    Post subject: R.I.P. Reply to specific post Reply with quote
If'n it's really dead it might be ready for a casket!
Jerry in VA
PostPosted: Sat Aug 11, 2007 12:34 pm    Post subject: Re: R.I.P. Reply to specific post Reply with quote
Rick (IA),
Where-abouts in Iowa are you? I grew up on a farm in Shelby County, later lived in ------, and went to U of I (Go Hawkeyes!).
Living in VA now, but many relatives back in the God's country.
Jerry
