allis No. 80 series "c" cultivator
S2mcgowan
PostPosted: Mon Oct 01, 2007 9:32 am    Post subject: allis No. 80 series "c" cultivator Reply to specific post Reply with quote
I'm looking for a copy of the No. 80 cultivator manual for an Allis "C". Does anyone have any pictures of a cultivator installed on a "C".
J.C.in AZ.
PostPosted: Mon Oct 01, 2007 3:36 pm    Post subject: Re: allis No. 80 series c cultivator Reply to specific post Reply with quote
Page 79 of the Book: Allis-Chalmers Tractors : A Motor Books International Publication,published in 1992, Titled [Farm Tractor Color History] with Text by C.H. Wendel,shows a very nicely restored AC "C" with a Mounted Two Row Cultivator owned by Ivan Henderson and at that time he still used it for Cultivation,sadly that was 15 years ago. Who knows the current status of the "C" or Mr. Henderson either for that matter ? .If I knew how to post a Picture here I could post it for you,but .
JMS/MN
PostPosted: Mon Oct 01, 2007 10:22 pm    Post subject: Re: allis No. 80 series c cultivator Reply to specific post Reply with quote
No pix or manual, but the front sections mount on a square bar that bolts to the front of the tractor, below and behind the radiator. Has a bolt (1/2 inch?) on each end to hold the left and right gangs, rear part of the gang bolts to the side of the tractor. Rear lift assembly mounts behind the fenders, with hyd cyl to operate it. Four pipes go forward to the four gangs mounted on the front. Rear gangs pivot on pipe brackets on the rear of each rear axle, plus hooked to the rear lift assembly.
spencer mcgowan
PostPosted: Tue Oct 02, 2007 4:25 am    Post subject: Re: allis No. 80 series Reply to specific post Reply with quote
I believe I have everything but the pipes that go from the rear lift to the front gangs. I'll have to find a set of those or dimensions to make them.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
