John Deere b clutch noise
tractormanq
PostPosted: Mon May 19, 2008 5:39 am    Post subject: John Deere b clutch noise Reply to specific post Reply with quote
Have a 48 john Deere B growling in clutch area, wondering where problem is coming from, seems to be noisier when going up hill , or while towing, any input appreciated, thanks, Quent.
Mike M
PostPosted: Mon May 19, 2008 7:01 am    Post subject: Re: John Deere b clutch noise Reply to specific post Reply with quote
Those have a real bad habit of the bearing on the end of the trans. input shaft being bad. This bearing is in that red. cover under an outer cover held on with 2 bolts to the rear of the belt pulley assy. You can pop that cover off and take a look real easy. If it is out and has been ran that way for years the red. gear may have a wear pattern set into the gears so even if everything gets all aligned up and tightened up you may still have noise from there,but usually not under a load instead of like now when it is under a load.
caleb in pa
PostPosted: Mon May 19, 2008 4:53 pm    Post subject: Re: John Deere b clutch noise Reply to specific post Reply with quote
hello, my 1939 john deere b does that all the times, especially when pulling, so does my 620 in 3rd gear when pulling, i say its worn gears since 3rd is the plowing gear and is always being used. just my .02 cents
Quent
PostPosted: Tue May 20, 2008 5:35 am    Post subject: Re: John Deere b clutch noise Reply to specific post Reply with quote
Thanks guy i'll start fishing for the problem.
