O.T. brake lights don't work, turn signals do?
Dave H. (CO)
PostPosted: Mon May 19, 2008 8:46 am    Post subject: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
I have a 1998 chevy k1500 truck, and this weekend I borrowed a trailer that had loose wires in the connector. My fuses blew for both my brakes and turn signals. I replaced both fuses. Now my turn signals work, my hazards work, my third brake light works, but the brake lights at the back don"t. (Yes, it"s the same filament as the turn signals) I have a relay under the hood that says "brake lamp relay". Could this only control the lights at the back and not the third brake light? I"d like to get this fixed soon so I can go get my brush hog from the welding shop. (Yes, it"s somewhat tractor related...)
Thanks in advance.
LP GAS ONLY
PostPosted: Mon May 19, 2008 9:09 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
I had a buddy's car do that once. It was the turn signal switch in the colum.
Gary
Dave H. (CO)
PostPosted: Mon May 19, 2008 9:15 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
The turn signals still worked in his situation?
ScottyHOMeY
PostPosted: Mon May 19, 2008 9:23 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Is it on the truck or on the trailer that you don't have brake lights? Are your truck and trailer lights on different circuits with relays between them?
Dave H. (CO)
PostPosted: Mon May 19, 2008 9:52 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
The problem is on the truck. I've used this trailer before and it's been fine. The problem was that a wire came loose in the trailer side connection and touched the other connectors.
Bob/Ont
PostPosted: Mon May 19, 2008 9:54 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
The power to the brake lights usually goes through the turn signal switch. Signal in center power goes to both brake lights. Signal Left and power goes only to the Right brake light. Signal Right and the power goes only to the Left brake light. That allows the turn signal to flash with brakes on. Short might have burned out signal switch.
Later Bob
Dave H. (CO)
PostPosted: Mon May 19, 2008 10:12 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
I don't like that train of thought! Is there any way to check the turn signal?
IH2444
PostPosted: Mon May 19, 2008 11:58 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
fuse ?
Roy in georgia
PostPosted: Mon May 19, 2008 12:15 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
you may have another fuse you are missing I know I have found them in both under the hood and dash under hood mostly for trailer and dash for vehicle.
John M
PostPosted: Mon May 19, 2008 12:53 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Did the same thing on my Z71. I think its the AC compressor relay is the same size relay as the brake light relay. Swap them and see what happens.
bradk
PostPosted: Mon May 19, 2008 1:16 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Wiggle the turn signal switch while stepping on brake pedal.If the brake lights come on or flicker,the multi-function switch is junk.Replaced many.
Dave H. (CO)
PostPosted: Mon May 19, 2008 1:47 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Thanks all. I"ll go through some more trouble shooting tonight. I"d like to think it"s not the $150 switch. Does the steering wheel need to be pulled to get to it? It has a tilt wheel and airbag if it matters.
bradk
PostPosted: Mon May 19, 2008 5:37 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Steering wheel doesn"t have to come off.Disconnect battery,remove upper and lower column covers,lower knee bolster(below column)to get at elec. connector.Take careful note when removing unit and install same way.
You"ll need a torx socket bit#20.
Leland
PostPosted: Mon May 19, 2008 11:41 pm    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
check the fuses under the hood your problem may lie there ,it's such a pain anymore to try to solve any vehicle problem
Dave H. (CO)
PostPosted: Tue May 20, 2008 5:37 am    Post subject: Re: O.T. brake lights don't work, turn signals do? Reply to specific post Reply with quote
Thanks for the info. Doesn"t sound hard at all. Last night I wiggled the turn signal and nothing happened. Due to the price difference and ease, I"ll replace the relay first, then move on to the switch.
