Author |
Message |
mikeintn Regular
Posted: Sun Jun 08, 2008 2:14 pm Post subject: firing order |
Can someone tell me the firing order on 1936 WC, I just trying to start one that been setting, hand crank, so I pulled it, but its popping out the ex. like the wires are wrong, I looked in the book I have and it said 1-2-4-3, but it dont seem right. Thanks: Mike |
Back to top |
papab New User
Posted: Sun Jun 08, 2008 2:35 pm Post subject: Re: firing order |
fireing order is 1342 |
Back to top |
JMS/.MN Guest
Posted: Sun Jun 08, 2008 2:43 pm Post subject: Re: firing order |
Firing order is 1-2-4-3. Usually cast into the housing that the magneto bolts to. Issue is- where is Number one wire installed? Sometimes top left, sometimes top right, rotation is CW, when viewed from the rear. Try both of those positions first. Otherwise, do the finger in the #1 hole, compression stroke, see where the rotor in the mag is pointing. Try all wire location options before tearing down the engine to see if the timing is set wrong at the cam gear. KISS formula. Sounds like it is trying to fire- good sign for a simple fix. |
Back to top |
KSTractor Regular
Posted: Sun Jun 08, 2008 3:15 pm Post subject: Re: firing order |
Most 4cyl firing orders are 1-3-4-2 A.C was different 1-2-4-3 |
Back to top |
leroy in ne Guest
Posted: Sun Jun 08, 2008 3:49 pm Post subject: Re: firing order |
don't know if this will be of any use but run into a similar situtation several years ago. after pulling a non runner about a mile we found that the original mag had been replaced with a different brand and rotor turned the opposite direction. switched wiring order for this, pulled less than 2 feet and had a sweet runner. leroy |
Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 96183 Location: Lake of the Ozarks area of MO
Posted: Sun Jun 08, 2008 5:18 pm Post subject: Re: firing order |
1, 2, 4, 3 as per the I-T manual. As a matter of fact all the Allis tractors from the B up to the WD45 used the same firing order. Which would include. B, C, WC, WD, and WD45
Hobby farm
Back to top |
mikeintn Regular
Posted: Mon Jun 09, 2008 4:28 am Post subject: Re: firing order |
Thanks for all the input, 1 is top nexts to engine, that whats cap got, then I did wire it clockwise, 1 2 4 3, I've forgot with out looking, but I know its the older mag. just got parts for it, point con. coil, I think [K], I know it dont make sense, but I took plug out, and the rotor is under number one, took valve cover off valves working ok, pull it a couple of times pops a lot out ex. sounds just like wired wrong, but I guess not, I think I'll just try it again, maybe the carb. could do it, It was froz up bad. |
Back to top |
MLPANKEY Guest
Posted: Wed Jun 11, 2008 2:42 pm Post subject: Re: firing order |
hmmm i thought ford tractors firing order was 1243 also interesting to know ive been wiring them up wrong must be how i bought the last for 400 it had a miss that the owner couldnt get out of it .allis firing order fixed that ford right up . |
Back to top |
