Model BC Sickle bar mower
old
PostPosted: Sun Jun 29, 2008 7:51 pm    Post subject: Model BC Sickle bar mower Reply to specific post Reply with quote
Well I let a friend borrow my sickle bar mower today. Well at dark he came back with it. Yep you guessed it he broke a part on it. So now where do I find a pitman arm bearing housing for one of those old things. Its the part that has 2 nubs on it and a bearing that drives the pitman. Part # 306377. I plan on checking with the AGCO dealer tomorrow but would also like a few other options
Hobby farm
Rod (NH)
PostPosted: Mon Jun 30, 2008 4:41 am    Post subject: Re: Model BC Sickle bar mower Reply to specific post Reply with quote
Hi Old,
I bought that part a few years ago. It is (or was) still available new from a dealer. Be prepared for a price shock though. You probably can buy a whole used mower assembly for the price of that part. Things like that are brutally expensive new and usually worn badly if used. I suggest you also look carefully at the pitman straps that mate to the nubs on that housing to see if they are worn oblong. If so, I'd expect the nubs on a new housing to wear prematurely. That particular joint is one that needs to be checked frequently for proper tightness. Once slop starts to be evident, wear increases rapidly. New straps will also be extremely expensive. BTDT. Check with an AGCO dealer of NOS AC parts.
I don't know of any other options. Mine wasn't broken but the nubs were excessively worn (as were the mating pitman straps such that a tight joint could not be had. At the time I toyed with idea of a weld build-up on the nubs but the machining would be impossible for me due to the taper involved and having it done professionally would be cost-prohibitive. Of course that would still leave the wear problem with the straps. Maybe you can cobble together something but in the end, I decided to bite the bullet and buy the NOS parts since I use the mower regularly.
PS: don't forget the thin hardened sleeve in the bore of that housing that the bearing rides on. It's like a speedi-sleeve without the flange. Mine was broken into three or four pieces. That sleeve does NOT come with the housing - it's a separate part.
Rod
old
PostPosted: Mon Jun 30, 2008 6:24 am    Post subject: Re: Model BC Sickle bar mower Reply to specific post Reply with quote
Call AGCO this morning, part if obsolete and can no longer be had. I remember years ago have a sickle mower that was a draw bar mount but it had the same sort of part and I had the same thing happen just wish I could remember how I fixed it then. Oh well guess if I don't find one very soon it will be something I fix the best I can and then cross my fingers that it works
Hobby farm
Sid
PostPosted: Tue Jul 01, 2008 2:49 pm    Post subject: Re: Model BC Sickle bar mower Reply to specific post Reply with quote
Did you try Payne Implement, Bolivar?
old
PostPosted: Tue Jul 01, 2008 7:59 pm    Post subject: Re: Model BC Sickle bar mower Reply to specific post Reply with quote
I tried a place that has been an Allis dealer for decades and they said the part is now obsolete so they can not get it and I would guess the place your talking about would be the same
ed in cny
PostPosted: Mon Jul 07, 2008 3:52 am    Post subject: Re: Model BC Sickle bar mower Reply to specific post Reply with quote
Did you try Sandy lake yet? I bet they could come up with a replacment for you.
View user's profile AIM Address
