WD45 - PTO
KEITH SCHRAMM
PostPosted: Mon Jun 30, 2008 1:59 pm    Post subject: WD45 - PTO Reply to specific post Reply with quote
Need help. I have a 1953 Allis. While Bush hogging I hit a rock in the field and my PTO quit. I tried to engage it again to no prevail. The only thing Ive done so far is check the out likage. Any ideas?
old
PostPosted: Mon Jun 30, 2008 2:22 pm    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
You probably broke the shear bolt. The WD PTOs have a shear bolt in the PTO drive to sort of save parts
Hobby farm
ohio
PostPosted: Mon Jun 30, 2008 3:41 pm    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
You hope you broke the shear bolt. More than likely it is an internal injury, but usually oil & shapnel would come out.
Very loose slipper clutches are the only way to B.H. with a wc-wd-wd45.
Brad W Wi
PostPosted: Tue Jul 01, 2008 3:17 am    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
Been there, done that. In my case it wasn't the shear bolt.It stripped the gears in the pto. Had to replace all the gears. not a huge job, just a pain in th a$$.
KEITH SCHRAMM
PostPosted: Tue Jul 01, 2008 12:57 pm    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
First of all, thanks for the help. So from what you all are saying, I need to remove the PTO unit and any damage would be in the PTO unit itself, not up inside the tractor.
Thanks again
Rock_Picker(MO)
PostPosted: Wed Jul 02, 2008 5:24 am    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
When you get the unit repaired, I recommend using a grade 2 bolt for the PTO shaft shear pin. It will sometimes be an aggravation because of nuisance shears, but in the long run it will most likely preserve your PTO unit. A half dozen bolts can be purchased at your local farm store for a few dollars. A few years ago I ran across a roll of old fence wire while bush hogging. The cutter has a slip clutch but it did not slip.......stripped the gears off the PTO unit.....luckily it was the external unit........good luck..........RP
Tim in NY
PostPosted: Wed Jul 02, 2008 1:20 pm    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
IF the shear bolt on the pto shaft isn"t sheared, then take the pto gearbox off and inspect the gears. Also check the pto intermediate gear which is inside the tractors torque tube. If that gear has been damaged, then check the pto drive gear by pulling the hand clutch cover (under battery box).I have the gears if you need them.
KEITH SCHRAMM
PostPosted: Sat Jul 12, 2008 11:20 am    Post subject: Re: WD45 - PTO Reply to specific post Reply with quote
Just my luck. I pulled the PTO housing and thats all fine. I pulled the inspection cover under the battery box and see that the PTO drive gear on the Torque Tube has all the teeth missing. What kind of job am I looking at. spliting the housing apart or can I fix this from the inspection cover were the torque tube and transmision cluch are. Thanks
