Bad sender unit?
ScottinBrooks,ga
PostPosted: Mon Jul 07, 2008 11:36 am    Post subject: Bad sender unit? Reply to specific post Reply with quote
Hi folks-
Just installed a new Agco OEM temp gauge on my 1969 180 diesel. The needle was kind of shakey, then went to full hot ( off the scale ) and stayed there, even though the tractor was cold.. Could the problem be a bad sender unit at the thermostat or is it the gauge? Trouble is the old gauge hasn't worked in years.
Thanks for the reply
DiyDave
PostPosted: Mon Jul 07, 2008 2:58 pm    Post subject: Re: Bad sender unit? Reply to specific post Reply with quote
Was the sending unit wired for 12V+ or 12V-, it makes a difference. An improperly rewired tractor could also be the problem.
ScottinBrooks,ga
PostPosted: Tue Jul 08, 2008 3:15 am    Post subject: Re: Bad sender unit? Reply to specific post Reply with quote
The sending unit was not replaced. It's the original. Only thing replaced was the gauge and I think it's correct.
JMS/.MN
PostPosted: Tue Jul 08, 2008 6:11 pm    Post subject: Re: Bad sender unit? Reply to specific post Reply with quote
With some tractors, you ground the wire to the sender, it should peg the needle- that means the sender is bad. No reaction, replace the gauge.
