730 gas w/ hiccups
Bill in Ia.
Guest
PostPosted: Fri Jul 18, 2008 8:46 am    Post subject: 730 gas w/ hiccups Reply to specific post Reply with quote
I recently bought a 730 w/ a gas engine. If I open the throttle too quickly w/o letting it warm up, it will hiccup and spit oil out of the air cleaner. The tractor has less than 900 hrs. on a complete overhaul. Is it possible the intake valves are not adjusted properly?
Jim Guarino, Agri-Service
PostPosted: Fri Jul 18, 2008 6:06 pm    Post subject: Re: 730 gas w/ hiccups Reply to specific post Reply with quote
Regardless of what brand tractor this may be, I would say that since the problem happens only when cold, that the carburetor mixture is too lean. The lean mixture does not burn properly, and the incoming air/fuel charge is ignited as soon as the intake valve opens on the next intake stroke. If the valve lash was too tight, the problem would be worse when the engine was hot. As a test, if the mixture is too lean, the problem will go away with a partial choke application. Other possible problems: the timing is not set correctly, the distributor shaft bushings are worn, bad condenser, bad coil.
Agri Services
o¿o
PostPosted: Sat Jul 19, 2008 1:36 am    Post subject: Re: 730 gas w/ hiccups Reply to specific post Reply with quote
Pat it on the back
