Allis B pto problem
farmerwannabe
PostPosted: Sun Jul 27, 2008 5:19 am    Post subject: Allis B pto problem Reply to specific post Reply with quote
Hi all, I bought a 1 1/8 to 1 3/8 adapter for our little B BUT the pin that holds the adapter on is way to large to fit in the hole in the B's pto. There seems to be a hole, but it's really small in diameter. Also, was there a swinging drawbar originally on a B? I can't figure out how to mount a sickle mower (trailer-type) so it would be far enough away from the pto to be able to work. It needs to be about 14 like a baler (on a larger tractor) doesn't it? Thanks for your help.
Mike in Ohio
PostPosted: Sun Jul 27, 2008 7:42 am    Post subject: Re: Allis B pto problem Reply to specific post Reply with quote
Our b had the round drawbar. Grandpa had a steel plate about 1/2" thick and about a foot long that mounted on two holes of the drawbar to move the mower about a foot farther back so the pto would work. The plate was the same color as the mower so I assume that it came with the mower but I really don't know for sure. Good luck , you might try ebay for a drawbar. Mike
ohio
PostPosted: Sun Jul 27, 2008 10:49 am    Post subject: Re: Allis B pto problem Reply to specific post Reply with quote
there is a swinging drawbar that gets the hitch to pto distance right.
chalmersbob
PostPosted: Sun Jul 27, 2008 1:59 pm    Post subject: Re: Allis B pto problem Reply to specific post Reply with quote
there is what is called a ASAE drawbar. It is a wedge shape plate that is mounted to the drawbar to push the implement back to allow the pto shaft to fit.
real easy to make one. there is a spec on it. I think it is min of 18" from hitch point to pto shaft. Bob
