Author |
Message |
oyen New User
Posted: Wed Jul 30, 2008 4:23 am Post subject: allis wd |
I converted my allis WD from 6V to 12V. I think I burnt up my coil because i didn"t get one with and internal resistor. I orderd one with and internla resister, but now i am thinking on spending the money for an electronic ignition. Anyone know if it is really better, and how tough would it be to put in? Thanks for any help in advance. |
Back to top |
Jack a Long Time User
Posted: Wed Jul 30, 2008 4:45 am Post subject: Re: allis wd |
Not worth it IMO. Remember to reverse the + and - on the coil and amp guage if you are installing an alternator negative ground system. I just had my generator rewound and converted to 12V. That way it still looks original but has the advantage of 12V starting. Just my preference. |
Back to top |
Texas Denny Long Time User
Posted: Wed Jul 30, 2008 5:38 am Post subject: Re: allis wd |
Is there an advantage to electronic ignition? That depends on your level of use. If you are a typical user in the 50's and are putting 2000 to 3000 hours on in a typical growing season, the electronic ignition will mean reduced downtime for tune ups. If your use is 200 hours per year or less, I think money would be better spent buying tires, oil seals to stop oil drips and new bearings to reduce drive sounds. |
Back to top |
MLPANKEY Guest
Posted: Wed Jul 30, 2008 5:54 am Post subject: Re: allis wd |
Yes electronic is the way to go the new points spring is not strong enough to stop point bounce . |
Back to top |
Posted: Wed Jul 30, 2008 7:41 am Post subject: Re: allis wd |
Could that be why I can't seem to get my WD timed exactly? It seems the timing mark bounces around and is not steady. I figured there is wear in the distributor and haven't yet taken time to investigate. |
Back to top |
Phill Snartland Guest
Posted: Wed Jul 30, 2008 10:07 am Post subject: Re: allis wd |
In my opinion (and I know everyone has one), putting the electronic ignition kit from Genessee into my WD-45 was one of the best improvements I've made to the tractor! Always starts, no plug fouling, no more points burning up. It's been great. Took about 15 minutes to install, and has been trouble-free since. I purchased the 12V, POSITIVE GROUND version of their kit, since that's how I'm set up.
Worth every penny in my book! |
Back to top |
oyen New User
Posted: Mon Aug 04, 2008 3:46 pm Post subject: Re: allis wd |
Thanks for all the help. Now i have another question. I put in a new coil with an internal resistor, and an new 12V battery. When i go to start the tractor up, it won't start, plus the battery cable on the negative terminal connected to the tractor frame starts to smoke and get really hot. My dad and I seem to think that it is a bad starter. Any help or info would be great. Thanks again. |
Back to top |
Dave W. New User
Posted: Wed Aug 13, 2008 4:20 pm Post subject: Re: allis wd |
The reason it's getting hot is because you have a bad connection. Clean bat. ter. and anchor bolt. |
Back to top |
