Author |
Message |
Tony Z Regular
Posted: Mon Aug 11, 2008 9:01 am Post subject: Allis 60 combine |
A local farmer has a 60 combine in his barn. No manual or anything. I was considering planting winter wheat. I am assuming that can harvest it, but does anyone know for sure? Also, does anyone have a used manual they want to sell? He has used it to harvest oats, but since he just feeds them, the husks stay on. I want to thresh the wheat so that we can use it in bread baking. I have never used a combine so any advice is appreciated. Thanks.
Tony Z |
Back to top |
Sid Tractor Guru
Posted: Mon Aug 11, 2008 9:42 am Post subject: Re: Allis 60 combine |
Yes it will harvest wheat. They are known for being able to do a pretty good job of cleaning the grain. You probably will need to do more cleaning after harvest for what you want to do. |
Back to top |
JMS/.MN Guest
Posted: Mon Aug 11, 2008 10:00 am Post subject: Re: Allis 60 combine |
The combine is called the All Crop 100 because the op manual lists settings for harvesting over 100 crops, including wheat. Wheat threshes easier than oats, so the settings are similar. Several basic settings, cylinder speed, concave clearance, chaffer opening, and sieve opening. Have you checked with AGCO to see if a reprint manual is available? dealer locator at www.agcocorp.com. |
Back to top |
TonyZ New User
Posted: Mon Aug 11, 2008 11:22 am Post subject: Re: Allis 60 combine |
Thank you for the replies. What do you mean by cleaning? Do you know how you would do that after the harvest? We have a few large families in our area that bake bread from scratch. We raise animals, but this is our first foray into this. Thanks. |
Back to top |
de Guest
Posted: Mon Aug 11, 2008 11:37 am Post subject: Re: Allis 60 combine |
Ebay usually has manuals for this machine or ty yazallcrop ( i believe thats the website) and its called the 60 because of the width of the cut. That website also carries parts and such. |
Back to top |
Sid Tractor Guru
Posted: Mon Aug 11, 2008 2:58 pm Post subject: Re: Allis 60 combine |
I think you will find this site helpful
Untitled URL Link
Back to top |
JMS/.MN Guest
Posted: Mon Aug 11, 2008 4:51 pm Post subject: Re: Allis 60 combine |
In case you do not find an op manual- when you thresh the wheat, it should be clear of the hull, not like oats. Without checking the book, I would say the cyl speed would be 800-1100 rpm, concave clearance about 3/8 inch, (gauges on each side of the cylinder), chaffer about 1/2 to 5/8 inch, sieve about 3/8 inch, maybe less. You want it open enough to let the threshed seeds fall through- not the chaff. Lower cylinder rpm in mid-afternoon when things are dry and hot, higher rpm in AM and late PM when straw is tough. If grain is getting ground, lower speed, open concave. Speed makes feed. Open the door on the left end of the machine to check if grain is being threshed from straw. If not, close the concave first, increase cylinder speed next, until all heads are threshed from straw. Rest of the operation is cleaning trash from grain. Best to get the op manual, tells what to look for at each stage, and how to correct it for a good grain sample. If you have no experience with a combine, you need the manual just to ID the parts I mentioned! Farmers have only one chance each year to plant or harvest- too late when you screw it up! |
Back to top |
TonyZ New User
Posted: Tue Aug 12, 2008 6:09 am Post subject: Re: Allis 60 combine |
Thanks! |
Back to top |
Alex Webner Guest
Posted: Tue Aug 12, 2008 5:02 pm Post subject: Re: Allis 60 combine |
I just got done refurbishing an all crop 66 and combined 12,000 lbs of wheat with it on 5 acres heres my # give me a call and i can go through what to look for on the combine and other things. 319-665-3130 Alex |
Back to top |
Paul from MI Tractor Guru
Posted: Tue Aug 12, 2008 5:30 pm Post subject: Re: Allis 60 combine |
Manuals were available from Allis a few years ago, maybe still. The correct sieve for wheat has oval openings. Yaz allcrop may have them. Manual will give you all the info need to adjust the machine & they are pretty simple so you can figure out anything else.
Paul |
Back to top |
TonyZ New User
Posted: Wed Aug 13, 2008 6:08 am Post subject: Re: Allis 60 combine |
Thank you for the detailed reply. I will print it out and save it! |
Back to top |
TonyZ New User
Posted: Wed Aug 13, 2008 6:09 am Post subject: Re: Allis 60 combine |
Thanks! I will give you a call soon just to pick your brain about wheat if nothing else! |
Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 24514 Location: Wapakoneta, Ohio
Posted: Wed Aug 13, 2008 5:49 pm Post subject: Re: Allis 60 combine |
The All Crop 100 was the selfpropelled machine that took either a 9' or 12' head, had nothing to do with amount of crops it could handle. The common pull type machines are the 60 that is a 5' cut, the 66 that is a 5 1/2' cut and the 72 that is an auger machine that is a 6' cut, then there is the larger pull type 90 that is an auger machine of about 7 1/2' cut and the smallest the 40 that is a 40" cut straight thru machine unlike all the others that discharge to the right. And there are 3 different versions of the 60 |
Back to top |
Leroy Tractor Guru
Posted: Wed Aug 13, 2008 5:54 pm Post subject: Re: Allis 60 combine |
Wheat and oats setting was the same. When we cut and shocked corn wheat was drilled between the rows of shocks, in spring after shocks were removed oats was sowen in those rows. In cutting the wheat would cut till come to oats strip, empty machine, cut oats and put in a different wagon and empty machine, go to next strip of wheat and on back and forth. No changing the settings for that 5' swath of oats. |
Back to top |
