Removing Starter from John Deere B Tractor
Diana from TN
PostPosted: Sun Aug 17, 2008 2:04 pm    Post subject: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
How do you remove the starter from a 1951 B John Deere Tractor?
Len, Cary NC
PostPosted: Sun Aug 17, 2008 2:14 pm    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
The starter should be in a case under the middle of the tractor, right behind the flywheel. As I recall there is a plate that is about 6 by 10 inches that you have to remove, which will open to the box that the starter is located in.
The starter is bolted into place so that the drive gear meshes with the flywheel ring teeth when engaged by the pedestal rod that goes down from the left side of the platfoem through the flywheel cover and activates the Bendix switch.
I am not exactly sure all of the above is precise, but it is close!
CAUTION: BE SURE TO REMOVE THE BATTERY CONNECTIONS BEFORE YOU WORK ON THE STARTER. I didn't do that once and nearly welded my highschool class ring to the frame of the tractor..Not a fun experience!
LEN
Diana from TN
PostPosted: Sun Aug 17, 2008 2:18 pm    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
Thanks for the help. That was what we thought but was unsure. We do not have the manual that come with the tractor. Thanks again.
Diana from TN
PostPosted: Sun Aug 17, 2008 2:31 pm    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
Is the Oil filter also located in the middle of the tractor in front of the plate that you remove to get to the starter.
johns48jdb
PostPosted: Sun Aug 17, 2008 4:07 pm    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
just a side note on safety: i know a man who got his ring caught between the ground and a hot cable at the battery. it got so hot so fast that when he jerked his hand back it pealed all the meat off his finger. when you walk in the shop have a place to hang your watch and ring. best to never even leave the house with them on.
Ric , Florida
You do not have to remove the oil filter to get at starter Once you remove plate 0n bottom of engin there is 3 bolts that hold starter in along with the cable going to starter Unhook cable from battery first Good luck Ric Tampa Fl
Len Bull, Cary NC
PostPosted: Mon Aug 18, 2008 7:39 am    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
We have at least enforced the need to disconnect the battery cable before you start the process! As I noted before, I still have the scars to prove that it needs to be done!!
LEN
36 coupe
PostPosted: Thu Aug 21, 2008 3:43 am    Post subject: Re: Removing Starter from John Deere B Tractor Reply to specific post Reply with quote
Ive never seen a mechanic wear a ring or metal watch band.I took mine off years ago when I hooked mine on the corner of a car body panel.Fellow I knew hooked a loose ring on a storm door handle, tore his finger up.My son in law gained weight and the ring got painful, had to cut the ring to get it off.Rings are bad news for mechanics and electricians or any one who works in electronics service.I worked for a farmer who lost the first joint of his ring finger when the ring hooked on some thing when he was working on a hay baler.If you get a burn from a ring the ring will have to be cut.
