volt meter
Cman
PostPosted: Sun Aug 24, 2008 12:42 pm    Post subject: volt meter Reply to specific post Reply with quote
I have installed a voltage guage on my AC B. As it turns out it is a battery condition guage.
This guage stays on about 12.5 with the switch off, turn the switch on and it registers no different. Crank engine and it moves to about 13.5 to 14. Seems to be working, but I question it staying on all the time. Other volt guages I have installed on different tractors parks to the extreme left with the switch off.
The B has an alternator and everything seems to be working right.
Any advise will be appreciated................
El Toro
PostPosted: Sun Aug 24, 2008 3:50 pm    Post subject: Re: volt meter Reply to specific post Reply with quote
If it isn't draining the battery I wouldn't worry about it. Hal
Den N Ms
PostPosted: Sun Aug 24, 2008 7:33 pm    Post subject: Re: volt meter Reply to specific post Reply with quote
Cman,If you want you could wire it up to ignition on side of a switch.But the drain on a volt gauge is very minute,so it would take a long time to drain the battery.
