930 gasket/ O Rings
R Wyler
PostPosted: Mon Apr 20, 2009 9:33 am    Post subject: 930 gasket/ O Rings Reply to specific post Reply with quote
Going to get the pistons back in my 64 930 lpg today and I opened the gaskets up sorting through them and my parts book and manual is not real clear. I will try to add pics here and if not I will post the link to my photo bucket page they are at the top. I found the tiny ones for the oil line inlets on top the heads. I know some are for the water passages there are six each of the ones pictured and where to those six little copper rings go?? Sorry for the questions this is the first time I ever had one of these apart and I really dont want to go together incorrectly or incomplete. I will post the link to my photo page if the attachments dont work. I really appriciate any help I will be back later on this afternoon to check in I will be putting in pistons in the mean time. Should I use some sealer on these gaskets? Thanks again for the help I am in a pinch here.
Untitled URL Link
R Wyler
PostPosted: Mon Apr 20, 2009 9:37 am    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
Also if you can tell me what and where these gaskets and rings go just call them 123 from left to right on those top pics and I will know which is which easily. The link should work the pics wouldnt post and I dont have time to waste. Thanks again Smile
Jimmie D. Phelps
PostPosted: Mon Apr 20, 2009 11:08 am    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
I can't tell where they go, but I was told by a good mechanic that you should use CRISCO on the O rings, both the little ones and the O rings at the bottom of the sleeves. Grease or oil will stretch the O rings and they will leak or not fit.
Nedd
PostPosted: Mon Apr 20, 2009 12:12 pm    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
The copper rings are for diesel fuel injectors, the other gaskets are hard to tell with out sizing them. I would say/guess the flat rubber rings go with the head gasket for the coolant (on head opposite side of push rods) the other orings are for plugs, like diesel fuel pump alignment. Just guessing on them......
R Wyler
PostPosted: Mon Apr 20, 2009 6:15 pm    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
Yes Jimmie that is what my mechanic friend told me to do. I used it on the sleeve O Rings when I put it together. Non petroleum is indeed the way to go on them.
R Wyler
PostPosted: Mon Apr 20, 2009 6:18 pm    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
Thanks Nedd yes I looked at the book again today and layed one of the gaskets on there and finally figured it out. Each head has 3 rings one for the oil passage and two for the outer openings for the outer push rods.
Nedd
PostPosted: Tue Apr 21, 2009 1:46 pm    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
Not seen any for just 2 pushrods. Try the opposite side of the head gasket. There should be 2 coolant holes there.
But there are many companies making gaskets. You probably have it right. Good luck
R Wyler
PostPosted: Mon Apr 27, 2009 7:57 pm    Post subject: Re: 930 gasket/ O Rings Reply to specific post Reply with quote
I checked again to make sure and that is the only direction those gaskets can go on and according to the books there are two O Rings for the two outer push rod openings and one O Ring for the oil passage.
