I290 /PTO WOES
olgentdc
PostPosted: Wed Apr 22, 2009 3:06 am    Post subject: I290 /PTO WOES Reply to specific post Reply with quote
Need a Schematic on the R/R of Pto Assembly of 1290 CASE ,,,,Engage lever is rocking with freeplay , because something uis loose and flopping around in there just waitin tio cog lock something EXPENSIVE , notorious for these David Brown tractors ,, tHANX FOR aNY HELP , JIM
casestudy
PostPosted: Wed Apr 22, 2009 12:43 pm    Post subject: Re: I290 /PTO WOES Reply to specific post Reply with quote
hi jim if you take off the toplink housing you will be able to see into the pto housing and see whats wrong, the pto in david browns is a simple setup. also it may be a broken pin in the lever on the outside that engeges the pto.hope this helps
