Stuck fuel valve seat
Hunter134
PostPosted: Sun Apr 26, 2009 5:49 pm    Post subject: Stuck fuel valve seat Reply to specific post Reply with quote
Thaought I was going to get my VAC started today, finished flushing the gas tank, new plugs , points, condensor, and coil. Hoked up the fuel line to the new sediment bowl turned on the fuel and gas ran right out of the carb onto the floor. Took the carb apart and am soaking it in aceton right now, but the fuel valve seat seems to be stuck tight, any tips on removing the stuck valve seat?
Nick@KY
PostPosted: Mon Apr 27, 2009 7:00 am    Post subject: Re: Stuck fuel valve seat Reply to specific post Reply with quote
Heat the seat and any jets you want to remove with a small propane torch.You may have to heat and let cool several time before it will come loose.Propane works better than acetylene because it does not get too hot.Good Luck and keep us informed. Nick
Hunter134
PostPosted: Thu Apr 30, 2009 5:54 am    Post subject: Re: Stuck fuel valve seat Reply to specific post Reply with quote
Thanks got the seat out carb is back together, Hopefulyy I"ll have time to play with the tractor this weekend....
