Did a 49 DC have a thermostat?
Ande
PostPosted: Wed May 13, 2009 7:54 am    Post subject: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
I dont have the tractor at home,and wondering if the 1949 "DC" came with a thermostat.Thanks
Gary D
PostPosted: Wed May 13, 2009 10:16 am    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
I'm sure they did. Buy sometimes folks took them out if they were running hot. A bad attempt to fix a problem that needed to be fixed the right way. Usually on my dad's farm, very fine dust plugged the fins in the radiator. A goon blow gun and lots of air took care of that. You would often need to hold a trouble light on the opposite side of the radiator to see how plugged up it was, and clean it out good!
RED BELLY
PostPosted: Wed May 13, 2009 10:18 am    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
YES AND THE CASE PART NUMBER IS A27563- CHECK WITH YOUR LOCAL CASE IH DEALER TO ORDER ONE
Mathias NY
PostPosted: Wed May 13, 2009 10:45 am    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
When I bought my '49 DC the radiator neck did not accept a thermostat. It could have been changed at some point earlier in it's life, but the paint (and grease) on it matched the rest of the tractor.
Clint Evans
PostPosted: Wed May 13, 2009 12:04 pm    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
For whatever it is worth, with all of my D series tractors, it was usually larger pieces rust out of the heads that would stop up the top tubes in the radiators. Then of course there was minimal water flow. I didn't ever have trouble with the air fins stopping up.
Tom Railsback
PostPosted: Wed May 13, 2009 2:00 pm    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
I just looked it up in "Full Steam Ahead;" thermostats were not used until 1952.
Old Iron Larry
PostPosted: Wed May 13, 2009 2:08 pm    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
My 49 DC did not have a thermostat, but I put one in by cutting out the center of the water outlet and installing a proper sized thermostat . Worked fine.
garytomaszewski
PostPosted: Wed May 13, 2009 5:46 pm    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
No thermostat, my 49 DC manual devotes a whole page to controlling the engine temperature with "shutters" to control the air flow through the radiator.
Gary D
PostPosted: Thu May 14, 2009 9:48 am    Post subject: Re: Did a 49 DC have a thermostat? Reply to specific post Reply with quote
Hah!!
I learned something new!! I knew about the shutters, but thought for sure they had a thermostat!!Sorry about the bad advice!
