AC 185 Power Director issue
hklvette
PostPosted: Mon Jun 15, 2009 6:15 pm    Post subject: AC 185 Power Director issue Reply to specific post Reply with quote
Hi all,
I"ve got a 185 with hydraulic PTO that the Power Director clutch doesn"t seem to disengage fully when placed in neutral. Its still shiftable, but its quite hard on the gears and takes quite a bit of effort to shift. I was thinking that the relief valve for the PD control needs a shim added. I don"t have the tools to test line pressure or i would do so. I have already checked to see if the shift detents line up properly, and they do.
Thanks in advance for the help!
L.D.W.
PostPosted: Mon Jun 15, 2009 7:31 pm    Post subject: Re: AC 185 Power Director issue Reply to specific post Reply with quote
Really, your foot clutch is to be used for changing gears, not the PD, most PD"s even when warm still have a little drag on the clutches. I would use your foot clutch, unless you like buying shifting forks............?
hklvette
PostPosted: Tue Jun 16, 2009 4:07 am    Post subject: Re: AC 185 Power Director issue Reply to specific post Reply with quote
my concern with that is constantly disengaging/ reengaging the PTO when a disk mower or baler is hooked up to it will put unnecessary wear on the implement.
Jack a
PostPosted: Tue Jun 16, 2009 7:45 am    Post subject: Re: AC 185 Power Director issue Reply to specific post Reply with quote
Absolutely do not shift the transmission using the PD. I never had
an issue with implement damage unless I was using a 2 lunger JD
and that happens no mater what way you shift or do with the PTO.
