Case 530ck diesel engine miss and knock
Bozrae1617
PostPosted: Wed Aug 05, 2009 2:58 pm    Post subject: Case 530ck diesel engine miss and knock Reply to specific post Reply with quote
I have a 530ck diesel that I have put on about 35 hours since I purchase it. While using it last night it developed a miss at higher RPM and also seemed to have developed a knock somewhere that I can"t determine, not sure if the miss is related to the knock? When I bought it I replaced the clutch and pulled off the oil pan to inspect the bottom end. It must have had a recent crank regrind because of the undersized bearing. The engine ran excellent with no misses and still holds 50 psi oil pressure at an idle, even with the knock. I do not believe the knock is crank and bearing related, but the knock has a deeper tone, and sounds about the same low and high rpm. I changed fuel and oil filters 35 hours ago. It appears to be getting a good supply of fuel.
Any ideas and suggestions on the problems would be greatly appreciated.
Roger (Mi)
PostPosted: Fri Aug 07, 2009 3:28 am    Post subject: Not good news Reply to specific post Reply with quote
A few years ago, a fellow had a 530 Case diesel with a knock coming from the engine. The oil pressure was good. When I pulled the oil pan, #3 connecting rod bearing was bad. The knocking came from the loose connecting rod itself and the #3 piston hitting the cylinder head. Had the crankshaft welded up then turned back to standard. Had to replace #3 connecting rod. Better pull the pan and closely check all of the connecting rods.
Bozrae1617
PostPosted: Mon Aug 10, 2009 9:23 am    Post subject: Re: Not good news Reply to specific post Reply with quote
Thanks for the advice. I figured I may need to pull the pan off, you confirmed what I was thinking, I was hoping there would be a simple solution.
