case 1070 hydrulic valve question
russ turner
PostPosted: Fri Sep 18, 2009 6:11 am    Post subject: case 1070 hydrulic valve question Reply to specific post Reply with quote
My 1070 hydro valve has had failure of the thermal valves, pt. no. A 13794. They are plastic and the stem bends causing loss of presure. Is there any alternative to these plastic valves. Thank You RT
mEl
PostPosted: Fri Sep 18, 2009 4:07 pm    Post subject: Re: case 1070 hydrulic valve question Reply to specific post Reply with quote
Not that I am aware of, the thermals warp because of extreme heat such as when the linkage is tight and doesn"t return keeping the system on high pressure for extended periods of times. They last for years otherwise. I would recommend just replacing them and take steps to keep the levers centering properly. You will not have a problem with them then. I have replaced lots of them and extreme heat is all that can cause it. mEl
russ turner
PostPosted: Fri Sep 18, 2009 6:52 pm    Post subject: Re: case 1070 hydrulic valve question Reply to specific post Reply with quote
Thank you mEL. We pull a swather cutting heavey crops in hot weather and the trans temp does get up there as there is no trans oil cooler. RT
Agri King
PostPosted: Fri Sep 18, 2009 9:26 pm    Post subject: Re: case 1070 hydrulic valve question Reply to specific post Reply with quote
Why is there no Hyd. oil cooler?
