allis chalmer engine wc
dan326
PostPosted: Thu Oct 22, 2009 4:24 pm    Post subject: allis chalmer engine wc Reply to specific post Reply with quote
My gramps has A-C and the water leaks in to oil it might be a seal or a crack in the block. So ive been looking around the net and from what ive found its an allis chalmer 1937 wc unstyled i was woundering what year engines would work in it and if they had to be from a wc only. thanks in advance for any info.
MLPANKEY
Guest
PostPosted: Thu Oct 22, 2009 4:59 pm    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
a wc had a 201 cubic inch motor. a wd also had the 201 . a wd 45 d17 170 gas and e gleanor combine had a 226 cubic inch motor which will also fit.
Aaron SEIA
PostPosted: Thu Oct 22, 2009 5:35 pm    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
Water in the oil is probably bad sleeve seals. Instead of swapping motors, why not rebuild what you've got? Parts are available and help is free here for the asking. Get a set of original AC manuals and maybe the I&T one as well and dive in. Simple to work on and might be a cheap fix.
Aaron SEIA
old
PostPosted: Thu Oct 22, 2009 5:56 pm    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
That could well be an easy fix or big problems. I have seen them have bad head gaskets, bad sleeve seals or a cracked head or block. I would open it up before you go looking for another engine. It should be the same engine as any WC or WD but not the WD45 but the WD45 engine will bolt right in just have more HP
DickL
PostPosted: Fri Oct 23, 2009 9:50 am    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
Always the first place to look is the core plugs in the head under the rocker arms. You should see water in the recess but to make sure, top off the radiator and watch for water appear while putting a little air thru a rag into the radiator. If they set quite a while low on water it will speed up the plugs rusting thru.
dan326
PostPosted: Sat Oct 24, 2009 4:46 pm    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
Will rebuild it if there nothing too wrong with it. I just wanted to just in case it is something we cant fix. Thanks for the info on the engines that will work guys. ps if i have any more ?'s i know who to call lol ghoustbusters! thanks again
dan326
PostPosted: Sat Oct 24, 2009 4:48 pm    Post subject: Re: allis chalmer engine wc Reply to specific post Reply with quote
Will rebuild it if there nothing too wrong with it. I just wanted to know just in case it is something we cant fix. Thanks for the info on the engines that will work guys. ps if i have any more ?'s i know who to call lol ghoustbusters! thanks again
