Author |
Message |
Peter Manders New User
Posted: Fri Dec 04, 2009 8:30 am Post subject: Case 2290 pulling gearbox |
Hello,
Can somebody help me out. We need a rebuilt transmission for a 2090 for farmstockpulling.
Rules 2700 RPM and airrestrictor 68 MM max.
What is possible or advice.
Thanks; Peter Manders Holland Europe |
Back to top |
ca.hess Regular
Posted: Sat Dec 05, 2009 6:36 pm Post subject: Re: Case 2290 pulling gearbox |
Explain what you need more throughly. Dont think forum members know what you need. Sure someone can help you with answers |
Back to top |
casemagnum Regular
Posted: Tue Dec 08, 2009 7:09 pm Post subject: Re: Case 2290 pulling gearbox |
Hopefully you have an 8 speed manual transmission or if you are running a lot of hp the powershift would hold up |
Back to top |
Michael Siebers New User
Posted: Thu Feb 11, 2010 10:53 am Post subject: Re: Case 2290 pulling gearbox |
Hello,
is there a chance to get a factory built 8 speed transmission for case 2090 and 2290?
I have only seen this tractor with power shift.
Thanks, Michael Siebers Germany Europe |
Back to top |
Posted: Thu Feb 11, 2010 10:58 am Post subject: Re: Case 2290 pulling gearbox |
Hello,
is there a chance to get a factory built manual 8 speed transmission for case 2090 and 2290?
Back to top |
mEl Tractor Guru
Posted: Thu Feb 11, 2010 4:15 pm Post subject: Re: Case 2290 pulling gearbox |
Peter , there were 8 speed 20-22's built early in production. There are way more 70 series boxes around over here and they are popular with the Case clan, even 30 series do just fine, there are people who use production range gear sets, mix and match to give a half gear jump between high and low range and there is a lot of interchangability between the 30-70 series transmissions in the range box. Google Elmers Repair on the web, He has some Super Stock class Cases, I think even some alky burners, in NTPA and will be invaluable to you in both knowledge and parts as you build. mEl |
Back to top |
