Case 440 starts then dies
David Carter
PostPosted: Fri Jan 08, 2010 10:27 am    Post subject: Case 440 starts then dies Reply to specific post Reply with quote
I have an 08 440 that is push snow with. It will start for about 45 seconds then die. I replaced the fuel filter and it acted the same. Also replaced the inline pump because i was told that it was the issue. Still no luck. At about 45 seconds to 1 minute it shuts itself down
Nitro
PostPosted: Fri Jan 08, 2010 12:01 pm    Post subject: Re: Case 440 starts then dies Reply to specific post Reply with quote
440 skid steer loader?
El Toro
PostPosted: Fri Jan 08, 2010 1:41 pm    Post subject: Re: Case 440 starts then dies Reply to specific post Reply with quote
If its a diesel the fuel may be jellin from the cold. If its a gas you need to check for fire to your plugs asap when it quits running. Could a problem in the ignition like the coil or ballast resistor. If it has good fire to the plugs there may be blockage in your fuel tank or ice if you're in a cold area. Hal
Tom (Ks)
PostPosted: Fri Jan 08, 2010 3:29 pm    Post subject: Re: Case 440 starts then dies Reply to specific post Reply with quote
It could be many things. It is possible that the battery ground cable may need to be cleaned at the frame. There are six relays in the fuse box on some 440's, one of them is an interlock relay. Switch the interlock relay with one of the others and see what happens.
