830ck 3pt
charley hellickson
PostPosted: Fri Jan 08, 2010 7:20 pm    Post subject: 830ck 3pt Reply to specific post Reply with quote
Hi all.
Is there a position control like one for depth and draft control and another for float on the 3pt? I bought an 830CK in June. Now using it on an 8ft. blade for snow. I have a U 302 Super MM that has the two positions in the 3pt. lever. Upper part is float and lower part is depth. I see there is a long flat lever under the seat on the floor board that has three holes in floor to adjust it. I was wondering if that was it? The hydraulics on the MM are acting up so I put the blade on the Case.
Thank you.
Charley Hellickson.
DKase
PostPosted: Sat Jan 09, 2010 6:54 am    Post subject: Re: 830ck 3pt Reply to specific post Reply with quote
The only depth control on the 830 CK is the position of the lever. If the lowering poppet is not set just right that could be a 6" range with the lever in the same position.
bradley martin
PostPosted: Sat Jan 09, 2010 4:42 pm    Post subject: Re: 830ck 3pt Reply to specific post Reply with quote
Charlie; Flat lever on floor controls the sensitivity of the draft-o-matic function of the 3 pt. As the 3 pt on these tractors was power-up only, there was no reason to have a "float" position on the valve(control). The SC and DC had a float position but not the 30CK series.
