1962 Case 530
Richard Andrews
PostPosted: Sun Feb 28, 2010 5:31 am    Post subject: 1962 Case 530 Reply to specific post Reply with quote
I recently got a 1962 Case 530 loader,I went to use it yesterday and the right rear wheel is locked up.Any ideas,Left side works fine
curtis larson
PostPosted: Sun Feb 28, 2010 6:32 am    Post subject: Re: 1962 Case 530 Reply to specific post Reply with quote
The ball ramps are rusty in the brakes. Cheap fix. Also check the cross shaft for the clutch.It needs lub. This can be done from the out side. When you push the clutch some times it will apply the left brake. But the total lock up is most likely from rust.
tom stanley
PostPosted: Sun Feb 28, 2010 6:34 am    Post subject: Re: 1962 Case 530 Reply to specific post Reply with quote
the brake has gotten moisture in it you need to take it apart and repairs should be as simple as clean up also check your rear end fluid make sure water is not present their also as a shifter boot or top cover gasket leak will cause this also good luck Tom
Richard Andrews
PostPosted: Sun Feb 28, 2010 6:38 am    Post subject: Re: 1962 Case 530 Reply to specific post Reply with quote
Thanks,its very possble,I was moving snow last weekend before it was parked in the garage which isn't heated.Thanks again
Richard Andrews
PostPosted: Sun Feb 28, 2010 6:44 am    Post subject: Re: 1962 Case 530 Reply to specific post Reply with quote
Thanks,I was moving snow last weekend before I parked it,its very possible.Thanks Again
