JD 2350 Steering cylinder seal replacement.
Leslie R Robb
PostPosted: Tue Mar 09, 2010 6:11 pm    Post subject: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
This is crazy because my brother and I replaced the seals on the left cyl about 10 years ago. For the life of me I can't remember how to get the cylinder rod out. Can anybody please refresh my poor old memory?
Les
Tx Jim
PostPosted: Wed Mar 10, 2010 4:09 am    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
PC 4187 for a 2350 lists 2 different style steering cylinders with no SN break. Later style has a snap ring on inside that I think keeps rod from coming out of tube. Earlier style cylinder I have not clue how to disassemble.
Leslie R Robb
PostPosted: Wed Mar 10, 2010 4:56 am    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
I think I have the model with snap ring. When you try to pull the rod out it makes a firm metal to metal contact. I think the end cap of the cyl assy has to unscrew but it won"t budge, and the uppper and lower allen screws when removed only allow you to see the chrome rod.
Tx Jim
PostPosted: Wed Mar 10, 2010 5:22 am    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
If the cyl is similar to a combine header cyl one removes the plug to unsnap ring through the hole. Not fun but can be accomplished.
Leslie R Robb
PostPosted: Wed Mar 10, 2010 10:15 am    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
I understand, but the rod stops before you can see the snap ring, and it looks like you could only replace the seals from the inside not the outside. I just don't get it.
TractormanNC
PostPosted: Wed Mar 10, 2010 4:45 pm    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Had to do this on a 2750 couple years back. Remove the hose fitting from the cylinder. Slide the piston until you can see the snap ring thru the hole where the hose fitting goes. Use a small screwdriver or something similar to work the snap ring off the piston. Reverse procedure to put snap ring back on. Going back on is HARDER.
Leslie R Robb
PostPosted: Wed Mar 10, 2010 6:18 pm    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Thanks a million, that explains a lot. I guess the allen screws are for draining and bleeding air out of the cylinder itself. I knew I couldn't see a ring from those holes. Years back we may have found out by accident but I'll bet a kind person like you gave us the clue.
Thanks for all ya'lls help
Les
Leslie R Robb
PostPosted: Wed Mar 10, 2010 6:24 pm    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Thanks for all your help and advice TX Jim, looks like in this case it was the fitting instead of the plug. Maybe this will help a lot more people.
Les
Tx Jim
PostPosted: Thu Mar 11, 2010 3:58 am    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Glad some one got you on right track. Lot's of water has run under the bridge since I've seen a cylinder similar to yours when I was a JD SM.
Leslie R Robb
PostPosted: Thu Mar 11, 2010 5:07 pm    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Hey you were right just had the wrong hole. And I should be kicked for not remembering just 10 years back. But at 64 the ole brain just won't work like it used to.
Did confirm access tonight and will try to remove ring this weekend. I have a pair of heavy duty snapring pliers with long (like needlenose) ends that may work like a charm.
Thanks again
Les
Allen57
PostPosted: Mon Mar 22, 2010 6:12 pm    Post subject: Re: JD 2350 Steering cylinder seal replacement. Reply to specific post Reply with quote
Leslie R Robb wrote:
(quoted from post at 21:07:53 03/11/10) Hey you were right just had the wrong hole. And I should be kicked for not remembering just 10 years back. But at 64 the ole brain just won't work like it used to.
Thanks again
Les
How did it turn out?
I paid the delership $117.50 to fix mine. Embarassed 90 labor and 27.50 parts.
