Case 970 clutch
Ken Johnston
PostPosted: Fri May 21, 2010 5:27 pm    Post subject: Case 970 clutch Reply to specific post Reply with quote
Tractor shifts fine util it warms up a little. I can't get it into gear after running it for 10 minutes or so. Not much pedle on the clutch either. Pulls stong. Doesn't slip. I could use some idea on where to start. I hate to think about busting it in half. I would be greatful for any ideas or information.
olgentdc
PostPosted: Fri May 21, 2010 7:43 pm    Post subject: Re: Case 970 clutch Reply to specific post Reply with quote
Times like this make it great to have a Qaulified Case dealer around ,or to have mEl right down the road to stop by for a visit with his guage set ,... find someone who understands the P/Shift ..... You will be $$$$ ahead , instead of payingfor someones education to learn on your tractor at your expense, ...
DKase
PostPosted: Fri May 21, 2010 8:11 pm    Post subject: Re: Case 970 clutch Reply to specific post Reply with quote
Can I assume that you have a straight 8 speed and conventional clutch? If so all that can be adjusted is the position of the pedal. If it holds good there is a chance that adjustment is all that is needed. There should be just a little free play on the pedal. To much and it will not release. Follow the linkage. Adjust it between the cab and the engine just behind the fuel filters.
dwag
PostPosted: Sat May 22, 2010 5:45 pm    Post subject: Re: Case 970 clutch Reply to specific post Reply with quote
If free pedal is correct, your looking at a split. Had one this spring with same symptoms. Dampener springs were breaking up and getting in the wrong places.
dwag
PostPosted: Sat May 22, 2010 5:47 pm    Post subject: Re: Case 970 clutch Reply to specific post Reply with quote
Above reply pertains to a dry clutch.
