54 Case VAC trans / rear end fluid
Kreg W
PostPosted: Sat Jul 03, 2010 4:57 pm    Post subject: 54 Case VAC trans / rear end fluid Reply to specific post Reply with quote
got my VAC running but now want to change the rear end fluid before I start using it. does ant one have a PDF of the fill and drain? I have found one drain directly below the seat and there is a fill on the left side below the dash, are these the only fill/drains on this tractor?? I don t want to miss anything while changing out fluids.
Thanks for any help in this..
K
kreg w
PostPosted: Sat Jul 10, 2010 1:04 pm    Post subject: Re: 54 Case VAC trans / rear end fluid Reply to specific post Reply with quote
HELLO !!!!!
mikefromiowa
PostPosted: Sun Jul 11, 2010 5:14 am    Post subject: Re: 54 Case VAC trans / rear end fluid Reply to specific post Reply with quote
the rear end fill for my '49 VAC is directly adjacent to the gear shift lever. I believe the fill for under the dash is for the hydraulic fluid for the eagle hitch.
