WD won.t start hot
JimDRIl
PostPosted: Fri Jul 09, 2010 2:48 pm    Post subject: WD won.t start hot Reply to specific post Reply with quote
MY WD pops off great cold, but won't restart hot. Barely Turns over when I try to restart. Almost new battery, tuned up recently.
fastsaws
PostPosted: Fri Jul 09, 2010 3:25 pm    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Sounds like a timing problem. If this started after the tune up check the points gap, distributor timing and spark plug gap.
old
PostPosted: Fri Jul 09, 2010 4:51 pm    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Turns over hard when hot is either timing to far advanced. Point gap wrong or a starter going bad
electraglider
PostPosted: Sat Jul 10, 2010 1:30 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Ihave the same problem on WD45. I check timing with light. The F mark on fly wheel is right where it should be. Spark plugs are gapped good. Will check the points, but not sure about starter. Rolls good cold, but engine barely turns hot?
olgentdc
PostPosted: Sat Jul 10, 2010 4:53 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
could be starter problems , and or ., bad conections EVERYWHERE ... try cleaning ALL ..
old
PostPosted: Sat Jul 10, 2010 6:52 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
A lot of times when hot a starter will bind up where as when cold it will spin just fine. That back in the day of headers caused big time problems with the hot rods of the 60s and they had to re-do many a header and or add heat shields so as to keep from smoking starters because of over heating
Jeff Z.
PostPosted: Sat Jul 10, 2010 7:28 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Then start it when it's cold. LOL
MLPANKEY
PostPosted: Sat Jul 10, 2010 8:03 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
in need of a valve job or piston rings can cause it also. try a little atf in the gas it might help might not.
JMS/.MN
PostPosted: Sat Jul 10, 2010 5:02 pm    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
If it has the magneto, not converted to the distributor, the magneto could need a rebuild. Try pull starting it when hot- if it starts easily, it"s the mag.
NCWC
PostPosted: Wed Jul 14, 2010 2:10 pm    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Try checking the coil. Sometimes they short on the inside and get really hot. Could cause your no running or no starting condition when its hot.
NCWC
PostPosted: Wed Jul 14, 2010 2:13 pm    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
electaglider
PostPosted: Thu Jul 22, 2010 7:41 am    Post subject: Re: WD won.t start hot Reply to specific post Reply with quote
Moved timeing back, and it starts fine hot now. Athought the mark is not right with the timing light?
