301 2800 timing compression
2800 diesel
PostPosted: Fri Jul 16, 2010 9:27 am    Post subject: 301 2800 timing compression Reply to specific post Reply with quote
I have a 2800 diesel out if a combine I have put into a tractor, where should the timimg be set and what should the static compression be? Thanks
Hurst
PostPosted: Sat Jul 17, 2010 8:33 am    Post subject: Re: 301 2800 timing compression Reply to specific post Reply with quote
Compression in that engine would be 16.25:1 if it is like the 2800 engines in the tractors. As for the timing, it will vary by the type of injection pump you have, as some injection pumps were static timing and some had automatic advances in them. I don't know the timing for either off the top of my head.
Hurst
Allan in NE
PostPosted: Sun Jul 18, 2010 7:51 am    Post subject: Re: 301 2800 timing compression Reply to specific post Reply with quote
Heck,
I'd leave that timing right where it is and put 'er to work.
If it starts and runs properly, the compression is okay. It takes somewhere in the neighborhood of 275 lbs for a diesel to pop.
Allan
