case 685 hydraulic pump
pleas
PostPosted: Fri Sep 17, 2010 8:17 am    Post subject: case 685 hydraulic pump Reply to specific post Reply with quote
Does the tractor have to be split into to replace the hydraulic pump
mEl
PostPosted: Fri Sep 17, 2010 4:27 pm    Post subject: Re: case 685 hydraulic pump Reply to specific post Reply with quote
The pump is mounted to the back of the valve ahead of the left rear axle housing, not a real hard deal to replace. Get with a knowledgable parts man to get the right pump as there were GPM options and different setups for each and gear mesh can be affected with mismatched parts. mEl
pleas
PostPosted: Fri Sep 17, 2010 4:58 pm    Post subject: Re: case 685 hydraulic pump Reply to specific post Reply with quote
Thanks mEl
pleas
PostPosted: Sat Sep 18, 2010 7:05 pm    Post subject: Re: case 685 hydraulic pump Reply to specific post Reply with quote
When you say in back of the valve do you mean the housing where the filter is?
mEl
PostPosted: Sun Sep 19, 2010 4:26 am    Post subject: Re: case 685 hydraulic pump Reply to specific post Reply with quote
That is correct, it contains the regulator spools, the PTO valve and generally is the heart of the hydraulic system. It's maybe 12 x12" and fairly easy to remove and replace. mEl
