Wc Front oil seal
Texas Denny
PostPosted: Mon Dec 06, 2010 5:17 am    Post subject: Wc Front oil seal Reply to specific post Reply with quote
My 47 WC has started to leak from the front oil seal. Can this be replaced without pulling the pan? Thanks, Denny
bjb in TX from Ne
PostPosted: Mon Dec 06, 2010 6:05 am    Post subject: Re: Wc Front oil seal Reply to specific post Reply with quote
If I recall right from when I rebuilt my WC, Yes, you should be able to replace the front seal. The front seal is in the front cover. I think the oil pan seal on a lip that runs on the front block. You may want to get a manual to double check. If you can get the front pulley off, and get the seal out, you may even be able to replace it without removing the front cover.
JMS/.MN
PostPosted: Mon Dec 06, 2010 10:49 am    Post subject: Re: Wc Front oil seal Reply to specific post Reply with quote
Yes- remove the radiator and front pulley. If you take off the front cover, be sure to center it perfectly before tightening the bolts. There is a bit of flex in the seal, so support the cover before tightening.
Texas Denny
PostPosted: Mon Dec 06, 2010 2:03 pm    Post subject: Re: Wc Front oil seal Reply to specific post Reply with quote
I"ve got the IT manual. Will try it this weekend.
Texas Denny
PostPosted: Mon Dec 06, 2010 2:04 pm    Post subject: Re: Wc Front oil seal Reply to specific post Reply with quote
Thanks. Will giver 'er a try this week end.
