3020 diff lock
uncle fred
PostPosted: Thu Jan 06, 2011 3:53 pm    Post subject: 3020 diff lock Reply to specific post Reply with quote
I have a 3020 that is a side console with no diff lock. I was told this was standard equipment on all side console 3020 tractors. Looking to find out if any were built without a diff lock? How to detect if it was removed? How to know if one can be added? In the event the rear end was replaced, is there any way to distinguish a late rear end from an early one for a 3020? Thanks.
buickanddeere
PostPosted: Thu Jan 06, 2011 4:47 pm    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
Two different diff lock setup for side console 3020's. It's all in the parts section of the JD site.
Serial #'s 150,001 and above are different for the pedals & linkage etc.
Locking diff it's self doesn't change above serial # 123,001.
If you really want a diff lock in there, it's going to take time and money in a 38+ year old machine.
I have often wondered if with enough time and money? If a HD Torsen worm gear locking diff could be transplanted inside an open tractor diff.
DIFFERENTIAL LOCK VALVE PEDAL AND RELEASE LINKā„¢BR>(TRACTOR SERIAL NO. 123000-150000)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 14H1076 NUT 2 3/8"
2 R34581 SWIVEL 1
3 11M7059 COTTER PIN 1 3.200 X 20 MM
4 24M7096 WASHER 1 10.500 X 18 X 1.600 MM
5 R45694 PEDAL 1 (SUB FOR R41005) (NLA)
6 AR40739 LINK 1
7 11M7079 COTTER PIN 2 0.098" X 0.472"
8 H858R PIN FASTENER 2
9 24H1136 WASHER 2 11/32" X 11/16" X 0.065"
10 R34522 STRAP 2
11 R26386 SNAP RING 2
12 R26385 PIN FASTENER 2
13 R34815 PIN FASTENER 1
14 11M7059 COTTER PIN 1 3.200 X 20 MM
DIFFERENTIAL (WITH DIFFERENTIAL LOCK)
1 R46162 SCREW 12 (SUB FOR R41049 AND R41354) (SUB R112882)
2 R33493 BEARING HOUSING W/O BEARING 1 L.H.
3 14H823 NUT 2 1/2"
4 JD8259 BEARING CUP 1
5 JD8954 BEARING CONE 1
6 R46323 SHIM AR 0.08MM (.003") (SUB FOR R26042)
R46324 SHIM AR 0.13MM (.005") (SUB FOR R26043)
7 R40235 CAP SCREW 10 - 150000 (USE WITH R34807)
R38614 CAP SCREW 10 150001 - (USE WITH R47711 AND T34236)
8 34H297 SPRING PIN 2 7/32" X 1"
9 AT33285 COVER 1 (MARKED R34807, R47711 OR T34236) (SUB FOR AR47835 OR AR34754) (ALSO ORDER (10) R38614) (SUB R101055 AND (2) R56504)
10 R34863 SPRING 2
11 AR69349 DISK 3 (SUB FOR AR33974) (SUB RE12518)
RE294033 DISK WITH INNER SPLINE 3 (SUB FOR RE239643 OR RE12518)
12 R34520 CLUTCH PLATE 2 (SUB R78155)
13 R78156 CLUTCH PLATE 1 (SUB FOR R34517)
14 R77145 WASHER 1 (SUB FOR R53202 OR R65741) (USE WITH R74869)
15 R74869 BEVEL GEAR 1 (USE WITH R65741) (SUB FOR R42620, R42447 OR R60008)
16 R42443 PINION 2
17 R74868 BEVEL GEAR 1 (SUB FOR R42445 OR R60007) (USE WITH R65741)
18 R77145 WASHER 1 (SUB FOR R53202 OR R65741) (SUB R93623) (USE WITH R74868)
19 R34526 PISTON 1
20 R41018 PACKING 1
21 R44327 WASHER 1 (SUB FOR R41019)
22 R41048 CAP SCREW 10
23 AR34823 HOUSING 1 (A) (MARKED R34806)
R34806 HOUSING 1
400R BALL 2
24 R68347 SHAFT 1 (SUB FOR R41902)
25 R70236 CAP SCREW 1 (SUB FOR R41050)
26 R34513 RING 2
27 AR34735 BEVEL GEAR DRIVE 1 (MARKED R34875 AND R34873) (SUB AR34722, (2) R26227, (4) R26228, (2) R33413 AND (4) R33414) (MATCHED SET) (SYNCRO-RANGE)
RE171047 BEVEL GEAR DRIVE 1 (USED PART) (SUB FOR AR34722) (ALSO ORDER (2) R26227, (4) R26228, (2) R33413 AND (4) R33414)
28 AR34736 BEVEL GEAR DRIVE 1 (MARKED R34875 AND R34874) (SUB AR34723, RE50113 AND R51200) (MATCHED SET) (POWER SHIFT) ( RE194088 USED PART)
29 JD8159 BEARING CONE 1
30 JD8210 BEARING CUP 1
31 R34529 BEARING HOUSING W/O BEARING 1 R.H.
(A) SUB COMPONENTS
MSM
PostPosted: Thu Jan 06, 2011 4:58 pm    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
Dif lock was an option, and most of the later tractors were kinda automatically ordered with it, along with fenders and 540/1000 pto,and at least 1 remote. Local collector has an original 2520 gas synchro with a fixed tricycle front,no fenders,no remote, no dif lock, a belt pulley, and a drawbar.
It can be added, the trans case has to be drilled/tapped for the oil feed line to pass through it and the differential carrier will have to be changed out for a lock type version. All the parts and lines can be had at a salvage yard
uncle fred
PostPosted: Thu Jan 06, 2011 5:13 pm    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
Thanks! My big question was if it was plausible to have a late 3020 without a diff lock and it looks like it is. So does this make it a "rare deere", you know one of those 1 of 22 built with or without a certain option for a given year, gas engine, row crop etc etc........?Smile Thanks again.
larryanderson
PostPosted: Thu Jan 06, 2011 6:22 pm    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
The diff lock was an ordered option that wasnt very expensive and hurts their value more than it cost.I have had about 10% of the side counsel tractors Ive bought not have diff lock.I was told the 69 4000 was not available with one.Collectable or not they are sure nice in snow or ice .
MSM
PostPosted: Fri Jan 07, 2011 2:33 am    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
No not rare. Alot did not have dif lock.
tim s
PostPosted: Fri Jan 07, 2011 4:08 am    Post subject: Re: 3020 diff lock Reply to specific post Reply with quote
Yes, they are not rare, and I think the trans. cases were all drilled and taped for the lines. With the proper stuf they could be added.
