Can't believe what I found!!
John Saeli
PostPosted: Tue Jan 11, 2011 6:55 pm    Post subject: Can't believe what I found!! Reply to specific post Reply with quote
Put the finishing touches on the 730 tonite. Had to replace a cracked head, never Ether'd or overheated, but anyway's. I let it run to warm up so I could re-torqe & I noticed the rocker arms weren't oiling properly. I pulled them off both heads & discovered they were never assembled correctly at the factory. Oil holes on the wrong side. I'm ashamed I didn't discover it in 1988 when she was majored, then in 2004 when I did a valve job. Will somebody please fire me??!!
Lamont
PostPosted: Tue Jan 11, 2011 7:34 pm    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
Sounds like someone should have been fired LONG before you!
Ande
PostPosted: Wed Jan 12, 2011 6:20 am    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
John,you cant be fired,your the boss,wait,your not the boss,Chris is!
Eric in IL
PostPosted: Wed Jan 12, 2011 7:21 am    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
I ran into the same problem on a Massey Ferguson 65. I did some technical reading in my genuine Massey service manual and my I.T. manual. They disagree on the direction the rocker shaft is installed. Then after looking the shaft over, I found the I.T. to be wrong. The I.T. manual went in the trash can.
olgentdc
PostPosted: Wed Jan 12, 2011 10:01 am    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
Glad to hear You got her up and going again,, Congratulations ,JOhn ... Re : , my (10 year all apart) 730 gasser had poor oiling capability,,we turned it every which way but loose .. added pint atf and put it to work raking ,,. probably need to take valve covers off and see how shes doing , but that is my favorite feeding and Wood hauler that Always starts , NO matter How Cold it Is ..
John Saeli
PostPosted: Wed Jan 12, 2011 11:27 am    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
Whether she's the boss or not, I let her think so, because "When Mama Ain't Happy, Nobody's Happy"!! Amen???
LenND
PostPosted: Wed Jan 12, 2011 2:45 pm    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
Hey! You think you are better than the rest of us. Join the crowd. LOL
Ande
PostPosted: Wed Jan 12, 2011 4:14 pm    Post subject: Re: Can't believe what I found!! Reply to specific post Reply with quote
AMEN!
