SC case
Ethan Chamberlain
PostPosted: Sat Feb 19, 2011 6:54 pm    Post subject: SC case Reply to specific post Reply with quote
hello
my friend and i have been working on an SC case for a while now and are still having the same problems. The tractor will start and run, but will slow down and then lock up. We can leave it sit, and then it will start up again and do the same thing. We have checked the oil pump out, and it is working. The tractor appears to have been rebuilt by the previous owner. We cant figure out what it is. Any help is appreitated. Thanks
olgentdc
PostPosted: Sat Feb 19, 2011 7:31 pm    Post subject: Re: SC case Reply to specific post Reply with quote
hope OTHERS CHIME IN ...If You Remotely believe that the crank is locikin up ..DO NOT CRANK IT ANYMORE , do no more harm !!!... pull the pan , and One at a time check the main bearings by Plastic Guaging , then do the rod caps , And ABOVE ALL ,, PLEASE ASK Questions and Disregard any bad mouthers ,. We Are Learning From One another Here .the Only foolish Question Is from those who refuse to ask questions ...
Patsdeere
PostPosted: Sat Feb 19, 2011 8:34 pm    Post subject: Re: SC case Reply to specific post Reply with quote
I second pulling the pan and checking everything. It sounds like something is getting warm and expanding then locking up.
DCTOM
PostPosted: Sun Feb 20, 2011 5:53 am    Post subject: Re: SC case Reply to specific post Reply with quote
pull the head and remove #4 sleeve, it will be full of rust so it cant cool, i had one like that and that is what it was dctdom
Ethan Chamberlain
PostPosted: Sun Feb 20, 2011 11:44 am    Post subject: Re: SC case Reply to specific post Reply with quote
We have pulled the pan and had everything apart. When we use the hand crank to turn it over, there is a definate hard spot where we have to really pull on the crank to get it to turn. The hard spot is still there with the pistons out of the block, the mains loosened up, all the pushrods pulled and the head off. So basically the only things left turning is the crank and the cam. I dont get it.
C. Amick
PostPosted: Sun Feb 20, 2011 6:33 pm    Post subject: Re: SC case Reply to specific post Reply with quote
Could there be something caught between two gear teeth? Let us know if you are able to figure it out.
j hekemper
PostPosted: Sun Feb 20, 2011 7:55 pm    Post subject: Re: SC case Reply to specific post Reply with quote
fast Work!... You mean you took the SC down Already ?...Strange that it is binding somewhere ? bent camm ????? .. can You pull it and see if it cranks easier ?
John Saeli
PostPosted: Mon Feb 21, 2011 6:14 am    Post subject: Re: SC case Reply to specific post Reply with quote
Is the clutch engaged or disengaged?
