WC Spindle removal
LWW
PostPosted: Sun Apr 03, 2011 11:00 am    Post subject: WC Spindle removal Reply to specific post Reply with quote
How do you go about removing the spindles from the bolster on a narrow front WC? I don't think they're welded in, and suspect they can be replaced, but don't know how they are removed. Any and all help will be appreciated, thank you.
Jim350
PostPosted: Sun Apr 03, 2011 11:23 am    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
I don"t think they were welded in.
There should be a pin holding the spindles in.
If yours are welded I would think someone did that. Not the factory.
JoeM(GA)
PostPosted: Sun Apr 03, 2011 12:56 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
.see if this helps
Photobucket
JMS/.MN
PostPosted: Sun Apr 03, 2011 12:58 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
Like the other Jim says- they are pinned. Clean it up well after removing the hubs, wire brush the paint, and you should find them. Often flush with the casting, so you need to look carefully for the telltale circle. I don"t know if they are tapered pins, but just in case, I would not pound on any end sticking out.
LWW
PostPosted: Sun Apr 03, 2011 1:51 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
That's EXACTLY what I was looking for, thanks for the help, guys.
Jim350
PostPosted: Sun Apr 03, 2011 2:08 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
Should be a straight pin.
60 acre hillside
PostPosted: Sun Apr 03, 2011 2:23 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
But I think they are only sold as an assembly.
Brian G. NY
PostPosted: Sun Apr 03, 2011 6:36 pm    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
I would think there are a ton of used ones out there, tho!
60 acre hillside
PostPosted: Mon Apr 04, 2011 3:02 am    Post subject: Re: WC Spindle removal Reply to specific post Reply with quote
The bearing sometimes turn and ruin the center part. The spindles should still be alright.
