Case 830 ComfortKing
Andy Sargent
PostPosted: Tue Apr 05, 2011 7:10 pm    Post subject: Case 830 ComfortKing Reply to specific post Reply with quote
1969 diesel Case 830 Comfort King case-O-matic with case bucket has developed a slow and weak hydraulic response. Hyd. fluid was tan and I assume water contaminated, changed fluid, no improvement. Am I looking at a new pump, or do I look somewhere else first? had this tractor from new and use it somewhat regularly.
Case Nutty 1660
PostPosted: Wed Apr 06, 2011 12:41 am    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
unless you had enough water in the oil to cause pump damage(can happen just not very often) your problem is in the hyd valve
andy sargent
PostPosted: Wed Apr 06, 2011 3:30 am    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
Thank you for the reply. I will look into that and see what it requires. Do you know if this means replacement or maybe just a rebuild?
Case Nutty 1660
PostPosted: Wed Apr 06, 2011 4:59 am    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
usally just a rebuild but be prepared parts are a little pricey, if you know some one with a flow meter it will help you in repairing your system cnt
andy sargent
PostPosted: Wed Apr 06, 2011 2:58 pm    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
Again, thank you for the response. I am a 'I like to do it myself, but have no experience' kind of guy and will probably search out a mechanic or tractor guy to help me out. Too much potential for screwing it up on my own.
Mike in Mn.
PostPosted: Thu Apr 07, 2011 5:19 am    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
My 830 Comfort King did that about 15 years ago, it was the pressure relief valve. There was an update kit that I installed and it"s had 1500 psi ever since. Have no idea if there is anything available anymore. Stick a 2500 lb. pressure gauge in one of the remotes and see what you have.
andy sargent
PostPosted: Thu Apr 07, 2011 5:28 am    Post subject: Re: Case 830 ComfortKing Reply to specific post Reply with quote
THANK YOU FOR THAT INFORMATION, I WILL SEE WHAT I CAN FIND. I APPRECIATE YOUR HELP!
