oil pan 430
sam un ont
Guest
PostPosted: Tue Apr 12, 2011 11:53 am    Post subject: oil pan 430 Reply to specific post Reply with quote
my 430 seized up so i removed the starter and tried moving it with a pry bar and found that i was able to move it but once it it a certain point i would hear a noise from the rear of the engine. pulled the plugs and put a rod in reach cylinder and rotated the motor and found that #4 piston was not moving. what i suspect is that either the rod snapped or the bearing cap. is there any way to remove the pan without taking half the tractor apart. it does have a front end loader sam
Bill_Utah
PostPosted: Tue Apr 12, 2011 12:28 pm    Post subject: Re: oil pan 430 Reply to specific post Reply with quote
Sam
I don't see what's to be gained by just removing the oil pan at this point.
Remove the loader
Remove the front end
Remove the engine
Disassemble, inspect repair and replace as needed.
Who knows what else is damaged in their when and engine stops that fast.
Just my thoughts
Bill
