Author |
Message |
tractorhank Regular
Joined: 19 Apr 2011 Posts: 23 Location: Lawrence, Kansas
Posted: Wed Apr 20, 2011 8:22 am Post subject: 37 Case CC oil |
I have a 1937 Case CC and I am getting ready to change the fluids. What weight and type of oil should I put in the engine and also in the transmission/differential? Also approx. how many quarts in each one? Does the CC have any kind of oil filter or screen that I should clean or replace? |
Back to top |
Dale Powell Guest
Posted: Wed Apr 20, 2011 9:02 am Post subject: Re: 37 Case CC oil |
Use 30 wt.detergent or 15- 40 multigrade in the engine. The gear case uses 90wt or 80-140 if you want to go fancy . Incidentally , I have a '35 CC I'd like to sell , would you be interested in expanding your collection ? I'm near Los Angeles. |
Back to top |
tractorhank Regular
Posted: Wed Apr 20, 2011 9:33 am Post subject: Re: 37 Case CC oil |
Thanks for the info. I am in kansas - too far to go to pick up a tractor otherwise I might have been interested. |
Back to top |
tractorhank Regular
Posted: Wed Apr 20, 2011 9:34 am Post subject: Re: 37 Case CC oil |
Back to top |
Dale Powell Guest
Posted: Wed Apr 20, 2011 12:30 pm Post subject: Re: 37 Case CC oil |
At $4.25 a gallon , I fully understand !! |
Back to top |
C. Amick Tractor Expert
Joined: 05 Mar 2009 Posts: 2401 Location: Wytheville, VA
Posted: Wed Apr 20, 2011 5:48 pm Post subject: Re: 37 Case CC oil |
Don't forget to drain the clutch housing when you change the engine oil. |
Back to top |
