rear wheel spacing
Don Wilken
PostPosted: Tue May 03, 2011 1:35 pm    Post subject: rear wheel spacing Reply to specific post Reply with quote
My Case 1194 has the rear wheels mounted with the deeply dished side to the outside, giving it a wide distance from wheel to wheel. Can I switch the wheels from one side to the other (dished side to the inside), giving it a narrower stance?
Thanks.
Don
Adirondack case guy
PostPosted: Tue May 03, 2011 2:00 pm    Post subject: Re: rear wheel spacing Reply to specific post Reply with quote
You can reverse the dish, and mount the rims inside or outside the dished wheel and switch sides with the tires and rims to get whatever tread spacing you want. All you have to do is keep the tire tread facing the wright way
Don Wilken
PostPosted: Tue May 03, 2011 2:10 pm    Post subject: Re: rear wheel spacing Reply to specific post Reply with quote
I didn't know I could make that many changes to the width. Thanks for the quick response.
Adirondack case guy
PostPosted: Tue May 03, 2011 2:44 pm    Post subject: Re: rear wheel spacing Reply to specific post Reply with quote
You should be able to obtain 8 different tread widths with those wheels. Common reasoning will guide you. Good luck, The Acg.
