case 430 crankshaft
sam un ont
PostPosted: Wed Jun 22, 2011 5:06 am    Post subject: case 430 crankshaft Reply to specific post Reply with quote
my old 430 [gas] had a severe lower engine knock and upon tearing it down found that #4 rod bearing was completely distroyed and had worn the crank down considerably' and found that the other bearings were well on there way out. i realize that i could have the crank built up but i was able to get what is suppose to be a good crank.. my question is does anyone have the specs. for this crank and also the clearances.the crank has 3 main bearings and has the# g11740 stamped on it. thank you for any help sam
Joe Young
PostPosted: Wed Jun 22, 2011 5:38 am    Post subject: Re: case 430 crankshaft Reply to specific post Reply with quote
Sam
The following are scans from the 430-530 OEM service manual. - Joe
Case Nutty 1660
PostPosted: Wed Jun 22, 2011 5:43 am    Post subject: Re: case 430 crankshaft Reply to specific post Reply with quote
here is the spark ign 430 specs you will have to blow up to read hope its OK on your end worked fine on mine cnt
Case Nutty 1660
PostPosted: Wed Jun 22, 2011 5:46 am    Post subject: Re: case 430 crankshaft Reply to specific post Reply with quote
hey Joe sorry didn't mean to double up and yours is much easier to read I 'll let you catch these Rock Island babies from now on thanks cnt
Joe Young
PostPosted: Wed Jun 22, 2011 6:54 am    Post subject: Re: case 430 crankshaft Reply to specific post Reply with quote
Naw....keep posting. More info is better than less.... - Joe
sam un ont
PostPosted: Wed Jun 22, 2011 4:45 pm    Post subject: Re: case 430 crankshaft Reply to specific post Reply with quote
thanks guys, that is exactly what i needed to get started sam
