Author |
Message |
Larry Jenkel Guest
Posted: Mon Jul 25, 2011 12:29 pm Post subject: 431 Case diesel injection pump |
My Case 431 with 188 engine injector pump is in bad shape. I have a chance to get a injector pump for a Case 580 with 188. Will this work? The new pump is a Roosa Master DBGFCC-431-65AJ. All I can make out on my old original pump is DBG. Thanks! |
Back to top |
Case Nutty 1660 Tractor Guru
Posted: Mon Jul 25, 2011 2:19 pm Post subject: Re: 431 Case diesel injection pump |
the 580( with a 188 or 207 Case engine) pump will bolt on but it should be set at 430 hp specs as the 580's were putting ot more ponies and may be hard on your drive train cnt |
Back to top |
j hikempr Guest
Posted: Mon Jul 25, 2011 7:27 pm Post subject: Re: 431 Case diesel injection pump |
drive train for 430 is same as 530 -630 ?rite ? and therefore 580 ,, adkguy told me that the fuekl pump settins is only diiference to make a 430 act like a 630 ,, not sure about 58 |
Back to top |
Larry Jenkel Guest
Posted: Tue Jul 26, 2011 12:32 pm Post subject: Re: 431 Case diesel injection pump |
Thank You very much! |
Back to top |
Posted: Tue Jul 26, 2011 7:21 pm Post subject: Re: 431 Case diesel injection pump |
not every thing is the same but with caution i have done it,, Case was pretty good about matching power train to hp unlike ih and a/c used to try ,,not picking on them at all just stating facts early 560's had "M" ring and pinions, wouldn't take that 6 cylinder power ect now am not trying to start a war OK cnt |
Back to top |
mEl Tractor Guru
Posted: Wed Jul 27, 2011 2:41 am Post subject: Re: 431 Case diesel injection pump |
When the 188 was in everything Case sold we kept a rebuild on the shelf at all times. We used that same rebuild for everything. It was set at 450 crawler loader specifications and the people with 430-530's never complained about the power increase and drive train longevity was not an issue. mEl |
Back to top |
