year of this L
grandpas te20
PostPosted: Mon Sep 05, 2011 8:28 am    Post subject: year of this L Reply to specific post Reply with quote
i am wanting to know if there are other ways to i d the correct year of this tractor i have a block number of 4446A does this help with the i d search and is there a production date any where on the tractor i can search for thanks
caseman-d
PostPosted: Mon Sep 05, 2011 10:53 am    Post subject: Re: year of this L Reply to specific post Reply with quote
Serial number should also be on the engine. Take first and 4th digit such as 382346 (3 and 3 - 3 = 193o.
caseman-d
Racine
PostPosted: Mon Sep 05, 2011 1:55 pm    Post subject: Re: year of this L Reply to specific post Reply with quote
Hi grandpas te20
You mentioned about the number cast into the engine block of your 1930 model "L", that is actually the cylinder block part number. However if you look on the left side of the cylinder block, and up in the top front, corner you will find a flat machined surface, on which will be stamped also with the tractors Serial Number. Unless at any time the block has been changed, or a new cylinder block has been put in, in which case there will be no numbers stamped there.
Hoping that this helps
Alan T. Lewis
Christchurch
NEW ZEALAND
grandpas te20
PostPosted: Mon Sep 05, 2011 1:58 pm    Post subject: Re: year of this L Reply to specific post Reply with quote
where would i find the serial# on the engine
C. Amick
PostPosted: Sat Sep 10, 2011 7:00 pm    Post subject: Re: year of this L Reply to specific post Reply with quote
It's stamped on the outside edge of the engine flange where it meets the clutch bell housing. I don't remember which side of the tractor.
