Case nutty 1660
danjwv
PostPosted: Fri Sep 09, 2011 5:12 pm    Post subject: Case nutty 1660 Reply to specific post Reply with quote
Evening
Thought you might tell me if a 411b com distributor will fit in a 430 case triple range. Thought I'd use it if it will work.
Thanks for your time. Dan. Danjwv
Case Nutty 1660
PostPosted: Fri Sep 09, 2011 5:31 pm    Post subject: Re: Case nutty 1660 Reply to specific post Reply with quote
yes it should work I have put a vac distriutor in a 530, I my ahve had to change the gear I can't remember cnt
Case Nutty 1660
PostPosted: Fri Sep 09, 2011 6:02 pm    Post subject: Re: Case nutty 1660 Reply to specific post Reply with quote
I must be losing my mind I chnged the gear because it was shot, the camshaft from a vac willfit in a 530 engine so the dist will interchange too no probs, little to much Caseon the brain cnt
danjwv
PostPosted: Sat Sep 10, 2011 6:44 pm    Post subject: Re: Case nutty 1660 Reply to specific post Reply with quote
Case nutty
Thanks foe the response back to the distributor question.
Not to tight to buy a new one when a used one will do.
If your ever in my country ,stop in and I'll give you the tour
Thanks again. Dan. Danjwv
