B manifold Threading. Dick L , maybe?
loveshisalis
PostPosted: Sun Sep 25, 2011 12:10 pm    Post subject: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
Hey dere;
I read that an 1" and a quarter inch tapered pipe tap is what to use to do the job in a Allis B stock manifold. Where can I pick on of these up, and then where do I get the nipple that goes inside of this?
precciate the help
Bob
PostPosted: Sun Sep 25, 2011 12:19 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
You can buy or order a 1-1/4" pipe tap for $$$$ at ANY hardware store.
You can probably find a reasonably good one on fleabay for a LOT less, or perhaps borrow one.
The pipe is simply 1-1/4" black pipe, even the "big box stores" probably have it in their plumbing dept.
DiyDave
PostPosted: Sun Sep 25, 2011 3:25 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
You can get both at McMaster-Carr, or MSC, or Enco. Google any or all of 'em
Bob Bancroft
PostPosted: Sun Sep 25, 2011 3:38 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
An AC B stock manifold was never threaded. And I would guess trying to thread an old one would bust it.
Dick L
PostPosted: Sun Sep 25, 2011 6:23 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
Old ones are easier to tap than new ones because the hole is a little larger. Takes less work to get the 1 1/4" tap down 3/4 the way on the tap.
I tap every one of my manifolds. All of my tractors set out side year around. seals the water out.
New one tapped in this picture.
I have a picture in my fotki site some where of one of the old manifolds that I had tapped. Couldn't find it just now.
loveshisalis
PostPosted: Sun Sep 25, 2011 7:29 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
hey DickL;
Thanks for the good tips. I might try that lifting trick using the stud girdle like you did. Sure daves having to pull the head bolts when lifting the mill ! .
appreciate all the good help
loveshisalis
PostPosted: Sun Sep 25, 2011 7:31 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
Hey DickL;
Also, do I have to pull the clutch off to replace the ring gear off the flywheel? I got that job coming up too.
In the menatime, got to line upa 1-1/4" tap, .
tanks
Bob Bancroft
PostPosted: Sun Sep 25, 2011 10:40 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
So many manifolds I have seen are so rotten you can hardly look at them, let alone tap them- I am impressed!
I wonder how many manifolds the average guys without your skill have busted?!
I suppose a manifold AND tap that are in good condition makes the difference.
Dick L
PostPosted: Mon Sep 26, 2011 3:24 am    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
A sharp tap does not put a great deal of out ward pressure when only turning the larger tap in an 1/16 to 1/8 of a turn before backing the tap up to clear the chips.
thebigyellowtruck
PostPosted: Mon Sep 26, 2011 7:56 am    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
have you ever tapped a WD all fuel manifold?(with the bolt on plate) if so what size is it? thanks
Dick L
PostPosted: Mon Sep 26, 2011 10:02 am    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
No sir, I have not. I have never owned a WD but you can find out what size of tap needed with a ruler or set the correct sized pipe nipple over the hole.
thebigyellowtruck
PostPosted: Tue Sep 27, 2011 5:57 am    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
thanks Dick. I think that will be a project for next spring.
steve(ill)
PostPosted: Tue Sep 27, 2011 2:46 pm    Post subject: Re: B manifold Threading. Dick L , maybe? Reply to specific post Reply with quote
look up "plumber" in the local small town phone book. Pay him $10, and let him tap it in 10 minutes while you wait.
