Convert from Gen. to Alternator
New Case Guy
PostPosted: Mon Sep 26, 2011 6:48 am    Post subject: Convert from Gen. to Alternator Reply to specific post Reply with quote
I have a 1962 W-3 Case Backhoe, 4 cyl. gas. The generator quit working so I took it to a generator repair shop. They told me it would be VERY expensive to fix and suggested I replace it with an alternator. Can anyone tell me how to wire it and what type of alternator to get? Someone suggested one form a 1980's Chevy pickup with only 1 terminal, but was only guessing. Also would my AMP. guage still work or do I need to change that or rewire it? My system is 12 volt, positive ground.
greginIN
PostPosted: Mon Sep 26, 2011 7:52 am    Post subject: Re: Convert from Gen. to Alternator Reply to specific post Reply with quote
should be a pieace of cake,Guy. just make up some brackets to mount the one wire altenator. then run the wire to your battery pos. terminal. i have all my case tractors converted over to this system, has saved a lot of headaches over the years. if your local stater repair shop is any good at all they can help you out with a alternator and questions. if you want to build your alternator there is lots of info on the subject on line. good luck.
Jo Bird
PostPosted: Mon Sep 26, 2011 8:08 am    Post subject: Re: Convert from Gen. to Alternator Reply to specific post Reply with quote
Look through old post by typing in generator in search section. All you need can be found their including wiring diagrams.
New Case Guy
PostPosted: Mon Sep 26, 2011 5:28 pm    Post subject: Re: Convert from Gen. to Alternator Reply to specific post Reply with quote
Jo Bird, thank you very much. Iwill try to find that.
