Apes rewired my TO-30
Cow
PostPosted: Fri Oct 07, 2011 3:06 pm    Post subject: Apes rewired my TO-30 Reply to specific post Reply with quote
Wild ones, with absolutely no regard for nice safe wiring.
Tractor was like this when I got it. I was planning on eventually getting an OEM style switch to replace the push/pull ignition control it has now and redoing the wires but something came loose and killed my ignition.
Not sure what the thing in the middle of the pic is. Is that a ballast resistor? I thought maybe a 12v to 6v voltage reducer but it has 12+ on each side according to my voltmeter so I'm guessing ballast resistor. Wires on one side go to the coil, the other side has 2 wires, one goes to the ignition switch, the other goes around to the other side of the engine and is hanging loose, the only thing I see it could have gone to is the alternator so I'm guessing that's where it went but I really don't know.
I can start the tractor and have it run by running a jumper wire from the battery + terminal to the ignition switch side of that doodad in the picture.
I've got a wiring diagram of sorts but it's for a + ground 6v system which if my tractor ever had, it doesn't now. [/img]
View user's profile AIM Address
Bill Brox
PostPosted: Fri Oct 07, 2011 3:26 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
If Apes rewired your TO-30, would you call that Monkey Business ?
I would have started to make myself a new wiring system, and got a new ign. switch.
From the pictures I think I would have been rather quick to disconnect the battery. Also that starter wire, the thick one, buy a little piece of shrinkable hose and shrink on the end, unless you get a new wire.
My dad"s old TEA 20 got on fire because of a spark and a small gasleak.
Bill
oldironman
PostPosted: Fri Oct 07, 2011 3:35 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
What's wrong with that wiring. LOL
Jerry/MT
PostPosted: Fri Oct 07, 2011 4:01 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Go to www.fergusonenthuiasts.org and look for a wiring diagram there. Your tractor has really been "farmerized".
Cow
PostPosted: Fri Oct 07, 2011 5:56 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Ok I see no doodad between the switch and coil in any wiring diagrams so I'm gonna just eliminate it and see what happens.
wisbaker
PostPosted: Fri Oct 07, 2011 7:15 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Wasn't even the intelligent apes, bet they were somewhat clever
Bruce(OR)
PostPosted: Fri Oct 07, 2011 10:04 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
The contraption in the middle is a voltage reducer. From 12V to 6V. Good for hooking up your OOGAH horn to 12V.
Cow
PostPosted: Sat Oct 08, 2011 6:49 am    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Bruce(OR) wrote:
(quoted from post at 01:04:40 10/08/11) The contraption in the middle is a voltage reducer. From 12V to 6V. Good for hooking up your OOGAH horn to 12V.
Hmm could have sworn I got 12vdc on both sides of it. Could it be broken or installed backwards?
Also will 12v burn out the 6v ignition.... If that's what I have?
Bruce(OR)
PostPosted: Sat Oct 08, 2011 10:11 am    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Unable to install backwards to the best of my knowledge. Might be no good. I suppose your machine does not run.
Also that resistor won"t work until you put a load on it. Voltage is potenetial. That 6V voltage drop is only going to work when the current is flowing. So, if it"s just sitting there with nothing working, you will see 12V on both sides. if it"s running, it will show 6V on the back side.
4on-the-floor
PostPosted: Tue Oct 11, 2011 2:24 pm    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
L.O.L. I'v seen worse,mine was allmost that bad and still not right. I thought i would just rip it all out and start over with new guages and all. That just might be my spring time job,right now i need to get it ready to remove winter snow with. Smile
Cow
PostPosted: Sat Oct 15, 2011 10:06 am    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Ok, so to make my life simpler I put in an electronic ignition conversion kit, 12v coil, and the factory ignition/light switch.
Got all that done, found out my alternator was bad. Replaced that. So now it all works... except I can't shut off the tractor properly because the field wire on the alternator is feeding back into the coil. SO, when I turn off the key the coil still has power and the engine keeps going. It eventually will loose power, sputter, and die, but not for almost a minute.
I guess I need something like a diode inbetween the alternator and coil.
Cow
PostPosted: Sun Oct 16, 2011 10:10 am    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
Ok, so it appears my field wire wasn't even needed. Does fine without it. Strange.
Xwild
PostPosted: Sun Oct 16, 2011 11:59 am    Post subject: Re: Apes rewired my TO-30 Reply to specific post Reply with quote
That's what I'm about to do with my TO-35. The wiring that is there is old, and patched in ugly ways... Just placed an order yesterday with Agri-Services for a new harness. Got to place my order to YT soon for a Pertronix coil and ignititor, regulator, plugs and wires.. Figure just start it all from scratch and know what I've got.
Think my regulator and coil are fine as is, but I have a feeling I'm never getting all the terminal posts freed up, so for a few extra bucks, I'm saving that hassle.
