wd horsepower
glenn veillon
PostPosted: Tue Oct 25, 2011 10:57 am    Post subject: wd horsepower Reply to specific post Reply with quote
i have a 1952 wd. how can i tell what horsepower it has. i have noticed on the internet some are 25 some are 30?? any help is appreciated
old
PostPosted: Tue Oct 25, 2011 11:37 am    Post subject: Re: wd horsepower Reply to specific post Reply with quote
If it is the gas one which is pretty much about all you run across any more it is right at 34HP as per the neb test list
jack bycraft
PostPosted: Tue Oct 25, 2011 12:16 pm    Post subject: Re: wd horsepower Reply to specific post Reply with quote
Most WDs by this time have had a least one engine O/H. I don't think anybody did an O/H using the standard WD kit the Power Crater kit of the 45 fit and cost very similar, so most have a much higher compression than standard. They have much more power. When I restored mine it got new gaskets manifold, rocker box and push rod cover left the rest alone. Recently dynoed at 36 hp. I believe a freshly run in O/H could reach a little higher.
glenn veillon
PostPosted: Wed Oct 26, 2011 3:17 am    Post subject: Re: wd horsepower Reply to specific post Reply with quote
the 49 i have is gas. i also have a 52 wd that runs on propane. would this have more or less hp.. thanks for the reply
old
PostPosted: Wed Oct 26, 2011 8:08 am    Post subject: Re: wd horsepower Reply to specific post Reply with quote
My list does not have propane but since propane puts out fewer BTUs then gas does it would also cause the tractor to have less power so figure around 30 or so for the propane burner
Albert Goerzen
PostPosted: Sun Nov 06, 2011 6:58 am    Post subject: Re: wd horsepower Reply to specific post Reply with quote
Remember altitute has a big effect on HP. About 3-4% for every 1000 ft above sea level. My well tuned WD makes 31 PTO HP at 3700 ft above sea level. That should correct to 35 HP at sea level.
